Results 1 to 3 of 3
Thread: RCD-310 not always changing stations correctly
    Anyone noticed any wierd behaviour when trying to change radio stations via the steering wheel controls ?
    You've got the left and right arrows to change station, and I've setup my system so that it should change jump to the next presets above/below the current one when you use the arrows.
    Under the setup menu, it is possible to leave the setting so that using these arrows scans for the next channel above/below the current frequency, but I have definitely changed this setting so that most of the time, it will jump from say 101.9 MHz to 102.7 MHz if that is my next preset station.
    90% of the time, it works as it should. However, if I haven't changed stations for a few minutes, and I press left, it jumps to the other FM menu (i.e from FM1 to FM2)...
    i.e
    It jumps from 101.9 to 107.5 and the presets shown completely change because it moves from FM1 to FM2.
    Anyone else suffering from this ?
    Jun 2009
    I think it is the feature of the system. As you push next to goto next preset, it will pick the FM1-Preset1, then Preset2 etc until the end...once it reaches the end of FM1 it will then move on to FM2
    GOLF V GTI DSG Silver : On loan to parent until wife thinks I am a responsible driver
    GOLF VI 118TSi DSG Silver Leaf
    GOLF VII 110TSi DSG White
    GOLF VII GTI pp : on negotiation
    Perth WA
    See this thread too.
    http://www.vwwatercooled.org.au/newf...ad.php?t=41227
    No answers there to my original question.
    Just what setup item affects this behaviour?
