No, Ever since I had the stage 1 tune I've run the BKR7EIX. I am having some curious issues with soft boost limp limiting me to 15 PSI. If I set the map to 98 mode and turn the ignition off it happens tends to be limited to 15 PSI boost. Also seems to happen when turning the AC off.
Resetting the map to 98 fixes it. Any suggestions related to that would be welcome. Going to get the car VCDS scanned next service over a few runs to see what it throws up.
