Results 31 to 39 of 39
Thread: Pump / motors / fans run after switching ignition / car off
  1. #31
    Sep 2010
    Sounds like the radiator cooling down the turbo or whatever after you turn it off.
    Does it sound like a loud fan going on?
    Same goes for my car, read its got something to do with cooling.
    MY11.5 118TSI - Reflex Silver Metallic, RNS-510, RVC + Park-Assist.
    Delivered March 2011 and on the road
  2. #32
    Jan 2010
    Melbourne, Australia
    Quote Originally Posted by grtuned View Post
    Manual or DSG???
    its a DSG - but not sure if the type of gearbox would make a difference?
    ---------- Post added at 10:04 PM ---------- Previous post was at 10:02 PM ----------
    Quote Originally Posted by dribs View Post
    I figured it was a cooling of some sort, but it was really noisy, so not sure if it should be that noticeable...
  3. #33
    Sep 2010
    Melbourne, Victoria
    Does it gradually get softer and softer or is it a whine that goes on for abit and suddenly ends?
    If it is the latter, then I would say it's the coolant after-run pump; shouldn't always run after every drive - it depends on how warm the engine is, etc.
  4. #34
    Jul 2011
    Does the noise go away when clutch is pressed in???
    Quote Originally Posted by 'fatboy' View Post
  5. #35
    Nov 2009
    Given it's a DSG, I think he'll be hard pressed to press the clutch in.
    As per DNA Tuning, I'd say it's likely to be the pump cooling the turbo after the engine is shut off - especially if you hear a loud click when the pump switches off.
    If you're not sure, just drop by your closest dealership and have them check it out, for peace of mind.
  6. #36
    Sep 2010
    Its quite noticeable, even when I first got my car back in March, I was like huh?
    Its nothing to worry about it. Yeah it sounds quite loud, but after 30secs or so, it'll just turn itself off. Having said that, the fan sometimes doens't turn on - depends on the temp. outside.
    I work at night, and when I drive home at 1am (esp. during winter) after a 10mins drive then turn the engine off, thn fan isn't running i.e. you can't hear the noise. So I assume its a cooler fan of some sort.
    Lately, the fan has been coming on when I come home at night, which I attribute to the warmer temperatures at night.
    Nothing to worry about!
  7. #37
    Jan 2010
    Thanks John / AdamD / dribs - I reckon that is what it is.
  8. #38
    Jul 2011
    Slacks Creek QLD
    Ya mine does it every blue moon I thought it sounded like turbo still spinning but I think it is the turbo pump
    90 TSI 1.4T
  9. #39
    Jul 2011
    my mistake
