Originally Posted by
Lucas_R
Hi and welcome.
There's a few things to be mindful off and definitely worth checking on the cars you are looking at or at least budgeting to replace after buying the car.
1) Timing chain and timing chain tensioner issues. The earlier engines (2009-2011) had a poorly designed timing chain tensioner which fails without notice and best case scenario you need a new head, worst case you need a whole new engine. In 2012 VW updated the tensioner design so that it could not longer fail so try to buy a 2012 onwards car if you can to minimise this issue.
Budget approx $1000-1200 to have the timing chain, tensioner and other related parts (timing guides etc) replaced by a mechanic if you do buy a pre-2012 car.
2) Inlet manifold issues. Runner flaps get stuck or break causing the engine to run rough and check engine light on your dash.
3) Water pump (leaks) so you loose your coolant over a period of time.
Quite a few Mk6 GTI's have had water pumps and inlet manifolds replaced under warranty.
Apart from these main things they are generally quite reliable and robust little engine.
If you are buying a DSG, make sure it has been serviced (60,000km or 4 years) and make sure it drives smoothly and changes gears swiftly and smoothly.
