Results 1 to 9 of 9
Thread: power steering getting heavier...
    Nov 2009
    Hills District, Sydney, NSW
    Turn the ACC to comfort mode
    Lake Macquarie
    No No No, the washer fluid reservoir has been overfilled causing too much weight over the front axle and hence turn in pressure. This has been found to exhibit itself more when pressing on causing understeer on corner entry but you will find that even given the extra weight up front the car is still keen to follow your inputs to tighten the line mid corner. I doubt even reasonably priced Euro’s would be able to match the turn response of a golf given an overfilled washer fluid reservoir .
    Golf R 5 Door DSG, Rising Blue, 19" Wheels (Silver), Leather, MDI, RVC, Bluetooth, RNS510, APR Stage 2, APR Divorced DP, APR HPFP, VW Racing CAI, S2T Paddle Shifters, Sprint Booster
    Aug 2011
    Quote Originally Posted by Klink1313 View Post
    Pfft, the real killer is constantly driving the car on the right, causing uneven Tyre-wear. Try driving from the left seat for a bit, it's a bit of a stretch but it's worth the savings!
    But honestly check your tyre pressure and tread.
    Dec 2009
    Sydney NSW
    thanks for all the er ....helpful suggestions
    Its most likely the tyre wear. Less tread = more rubber on the road = more friction I suppose. Can't believe I've nearly worn down a set of tyres in less than 20000km...
    Mk VI GTI 2 door Manual, Park Assist, RVC, RNS 510
    Lake Macquarie
    Your wlecome.....always happy to help
    Dec 2008
    Sydney/Canberra
    Keep your tyre pressures up to around 38PSI.
    If they're low, you'll go through tyres like they're going out of style.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
