Looks like there may be a coding issue in the car, possibly either the gateway or central electrics control unit. The door issue is basically showing that the central electrics thinks that the car is a LHD vehicle.
ABS module is down under battery, between the gearbox and firewall. You shouldn't need to remove anything more than just the intake pipe/airbox possibly. However the plug is abit of a POS to disconnect. I'd disconnect it, lock the car up and leave it 30mins to an hour, reconnect and rescan it.
