Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Performance enhancement and warranty
    Nov 2009
    NSW
    Hi All,
    Are there performance improvements i can make to the GTI that will still be covered under warranty?
    Cheers!
    Jun 2009
    According to most dealers, there isn't any.
    However the APR tune is meant to be hidden so should be okay.
    Lightweight wheels and removal of deadweight (spare tyre, rear seats etc) shouldn't cause any problems.
    The only real problems come when parts that need to be replaced/fixed under warranty can be claimed to have failed due to the performance enhancements you have added.
    Dec 2009
    Quote Originally Posted by Mk6 GTI View Post
    I've been wondering the same thing. On Pages 13-14 of the service schedule book in the warranty section it states you must pay for the cost of repairs, replacements and adjustments that are necessary due to:....modification or alternations that have not been approved by Volkswagen, including installation or use of non-genuine or non-approved parts, accessories, equipment, assemblies, components or agents....
    So in others words only performance improvements that are Volkswagen approved would be covered.
    Black Golf Mk VI 118TSI Manual Sports
    Point Cook, Vic
    the best thing you can do in regards to this issue is establish a good relationship with your dealer.
    FOLLOW US ON FACEBOOK
    Oettinger has an engine / drivetrain / breakdown supplemental warranty for up to three years on a new car.
    Purposely designed to cover any gaps left by the factory warranty.
    www.oettinger.com.au
    Erskineville, NSW
    Hi All,
    Cheers!
    Better tyres & lightweight quality rims are a performance enhancement that should not affect warranty.
    Just about anything else (suspension improvements, remaps, etc) give VW an opening to negate warranty on related items. eg: a remapped ECU won't affect the warranty on the windscreen wiper motor.
    Jun 2009
    Perth, WA
    Would modifications also affect your insurance cover?
    Feb 2009
    Quote Originally Posted by MovieDude View Post
    Could do, best to check with your insurance.
    Mods should be done knowing you could void your warranty in those areas, otherwise leave it stock.
    Erskineville, NSW
    All insurance companies are different. You need to ask them.
    Dec 2009
    Aftermarket tune effect on VW Warranty
    A thread has been running currently regarding 118TSi engine failures due to broken pistons and/or rings. This raises an interesting question in my mind.
    Am I correct is assuming that the fuel map (tune) determines mixture which may have contributed to burnt pistons through a lean mixture?
    If this is so then the rebuild/ replacement is an obvious warranty repair.
    Which is OK while the warranty is current or you have a factory 'tune' installed.
    A failure out of warranty would require negotiation and possible factory repair but what if there's an afterrmarket tune installed.
    I read on this forum that aftermarket tunes don't affect warranty. Well I would think good luck to anyone who returned the car to VW with a failed piston and anything other than a factory tune installed.
    Seems like a great risk. a few extra Kw and the chance of a huge repair bill.
