Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Perfect iPhone Holder In Golf 6?
  1. #21
    Feb 2008
    Richmond, VIC
    Quote Originally Posted by mikinoz View Post
    I'd suggest you forget about those clip on the vent solutions if you care about your car).
    I care for my car and i have no issue with this type of bracket, I'd certainly rather use that than having to dismantle the dash to wedge a bracket in.
    CAR AIR VENT MOUNT HOLDER CRADLE APPLE IPHONE 3GS 3G S - eBay, Other Mobile Accessories, Mobile Accessories, Phones. (end time 27-May-10 21:15:47 AEST)
    For less than $10 its a bargain and i can safely remove and fit the bracket in a second without causing ANY damage to car or phone.
    currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
    previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
  2. #22
    May 2009
    Townsville,QLD
    Aug 2009
    Melbourne, Vic
    I don't own an iPhone although I nearly did. I got the far more capable Google Nexus Phone instead. But my wife has one and I just popped her Belkin cradle into my MK6 for the hell of it to see how it fits.
    If you are after a simple neat installation that works well this might fit the bill. On the rear of the charger there is a USB outlet to charge other stuff AND a 3.5mm outlet to feed the audio to your MK6. You can quite readily run a lead from this back to your AUX input in the center armrest.
    The cradle itself allows the phone to rotate between 9, 12 & 3 O'Clock positions if you prefer it landscape. The button at center bottom contains and extra Mic for hands free use. Single Press the button to answer or hang up calls. Double & Triple press does other stuff which I cannot recall.
    Main bummer is you also need to plug the 3.5mm lead visible at top left of the phone in, to get "audio out" feeding down to the other end of the device and its 3.5mm outlet.
    If you dont do this it still charges fine and uses the phones speaker. But the audio does not pass on to your Aux input.
    There are two version of this Belkin iPhone kit. This one with the 3.5mm Aux out and another that included an FM transmitter. I wouldn't recommend the FM transmitter version as it has had bad reviews. Both still require you to plug the 3.5mm jack into the phone itself for audio to feed to your car.
    Still it is a solution to consider for the Iphone MK6 combination. It is fairly neat and tidy, Charges the Iphone well, can be used with a case on the phone and it feeds audio to the car if you can be bother to hook up the 3.5mm leads.
    PS forgot to mention it cost ~ $60 from memory.
  4. #24
    May 2009
    Townsville,QLD
    Quote Originally Posted by logger View Post
    You get all this in the one above, for half the price
    2009 125TDI Passat
    2002 B5.5 1.8T Passat
  5. #25
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by BrettD View Post
    You mean the one that links to "This listing () has been removed, or this item is not available."
  6. #26
    Nov 2009
    Hobart, Tasmania
    Thanks for that logger. I have been wondering for a while how those bendy-arm cradles work in the horizontally position 12V port in my MKV but it seems that it is flexible enough to be quite useful. Might have to check that out
  7. #27
    Aug 2009
    Melbourne, Vic
    Yeah the stalk whilst stiff, is not stiff enough to prop the iPhone up in the middle betwen my two heater control knobs. (not that you would want it there anyway). You generally need to arrange it in a positition where it leans on something like the left of the center console as in the picture. Otherwise it will tend to drift about when you hit bumps. Where the stalk attaches to the cradle proper there is pivot that allows you to rotate the phone left or right to landscape orientation and when doing so the phone will stay put in its new orientation. As the Belkin stuff is of a reasonable quality, the charger will be half decent and should have sufficient milliamps to charge the phone and run the GPS concurrently.
  8. #28
    Perfect Iphone 3G(S) Holder In Golf 6?
    I have that belkin cradle thing and the handsfree button fell apart. Also the sound quality wasnt the best.
    Im gonna try the griffin tuneflex one next as it draws audio from the dock connector instead of the headphone jack.
    84 MK1 GTI
    01 DC2R
  9. #29
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by Big Yellow View Post
    ...Im gonna try the griffin tuneflex one next as it draws audio from the dock connector instead of the headphone jack.
    That would be a much better solution. Connecting the 3.5mm is a PITA.
  10. #30
    Nov 2009
    Hobart, Tasmania
