Results 11 to 20 of 34
Thread: Park Assist or Reversing Camera? Or both?
    Jan 2010
    brisbane
    nah dont get it, park assist is good enough. spend the extra 500 or so saved by donating to vwwatercooled to upgrade the server to cope with extra threads
    Feb 2009
    I'm still undecided about park assist but wouldn't mind the camera as it's pretty cheap $500.
    But as hoi polloi says the main reason you'd get park assist is for the sensors.
    Still think it's a gimmic though and not requ'd on a small car, one or the other would be plenty if you do need it.
    Oct 2006
    If you can't park a Golf maverick im REALLY worried. Its like reverse sensors on a swift, seriously lol
    How do truck drivers do it? not all have camera's, usually only over 4.5t do.
    Feb 2009
    You're right, its just a way of extracting money from buyers and making you second guess your abilities as a driver.
    The camera may as well for $500 as the badge lifts up and interfaces well with the head unit..
    I'd get more enjoyment out of a sunroof than park assist i think as my parallel parking is pretty good.
    Jan 2008
    Quote Originally Posted by fuzion View Post
    Truck drivers don't normally reverse their trucks around children and animals or in tight areas where there are low bollards and other obstacles.
    As I said and you decided to ignore the rear visibility from a Golf is worse than many much larger cars and 4WD's.
    By all means ignore all the evidence and keep your "small cars have no blind spot so don't need sensors and/or cameras" stance. I guess small cars don't need stability control or abs either?
    Feb 2009
    bigger trucks such as garbage trucks aren't allow to reverse over a certain distance and not without another person standing behind the truck guiding them.
    Jan 2008
    Quote Originally Posted by G-rig View Post
    I like that, we could get all the unemployed to stand around on the streets waiting for cars to reverse so they could guide them
    Feb 2009
    Sydney, Australia
    As much as I agree with your sentiment that it should be easy to park a Golf because it is relatively small - you are missing the point of the RVC as Maverick is pointing out. One of the car organisations rates 'rear visibility' of cars by doing witches hat tests and reporting which ones they can see out the rear. Unfortunately the Golf would shock many as being very bad in this area. Maverick isn't exaggerating when he says that all those cars you have mentioned have better rear visibility than the Golf.
    So whilst I do agree that yes, REGARDLESS of rear visibility you should be able to park the Golf using your spatial awareness, your spatial awareness will not let you know that a child is just about to walk under your rear tyre etc... THAT is the purpose of the RVC.
    Feb 2010
    Melbourne, VIC
    I do agree with coreying regarding the Reversing Camera, and the cost of it is so minimal ($500) it will pay for itself in the event that a child/animal/anything comes behind the car and you cant see it.
    However the Park Assist is something different all together.
    Dec 2009
    I went with the Park Assist .. and I can park perfectly fine.
    It's a safety, convenience feature for me. For $1500.. it wasn't a big stretch for me.
    2019 BMW M3 CS
