Results 31 to 38 of 38
Thread: Park Assist Issues / Problems
  1. #31
    Apr 2010
    Adelaide, South Australia
    Quote Originally Posted by Dermot View Post
    Push the Park Assist Button once it will give you left hand side, push it a second time it will give you right hand side
    so this must have changed with software as i m sure i only had to press it once and it would do a detect which side i am doing a park or was it always like this?
    GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
  2. #32
    Apr 2010
    Quote Originally Posted by aVex View Post
    Actually from my experience, by default it's the passengers side. To have it scan on the drivers side, you need to turn you signal indicators to the drivers side and then park assist will change it's scan to the right. (It's in the user manual).
    it does make sense to be passengers side, by default....but cant recall if i placed an indicator when i used to park...will pay more attention tonight to try it before driving it back to the VW service....
  3. #33
    Quote Originally Posted by night_flight View Post
    I have to use the indicator to use the park assist on the drivers side otherwise it defaults to the passengers.
  4. #34
    Mar 2008
    Canning Vale, WA
    Quote Originally Posted by MkVIGTI View Post
    From my understanding Oz delivered park assist should only be able to park on the passenger's side, as is the case with my car. They may have delivered the car with a wrong software when you first picked it up. As for DRLs you can turn it on via the stalks. Refer to you manual.
    I thought the DRL's were set on/off by the MFD settings menu?
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
  5. #35
    Jun 2011
    sydney
    Quote Originally Posted by ralp2dam View Post
    Yep thats exactly how it works as standard.
  6. #36
    Feb 2009
    Sydney, Australia
    It seems that the confusion here is that the operation of it has changed along the way.
  7. #37
    Apr 2010
    thanks all it seems now indicator has to be used for the car to scan driver's side otherwise it wont park. thanks all problem solved!
  8. #38
    Mar 2010
    I thought only the overseas models have PA on both sides, have to go and play around with it some more
    Quote Originally Posted by T Go View Post
    Only the newer cars with the new MFD software has that option. We have to use the stalks to turn it on/off.
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
