Problem solved! Couple of wires fused in the engine harness right underneath the manifold! Replaced burned wires, insulated every other wire, some 50 of them, tested, started, no lights on dash, no codes, works perfect. Maybe I should have bought new harness but don't really want to give money to the vw after the cheat. Needless to say this is my first and last vw. Merc or Bmw is next and if that is too much a Toyota is a safe bet. Thanks for your help guys, this is a second solved issue I shared. Good luck.
- You may not post replies
- You may not edit your posts
Forum Rules
