Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Over assisted / servoed / sensitive brakes
    Keilor, Vic
    Hi,
    I am or was at the point of buying a new Golf 118TSI Comfortline DSG, but there is a major flaw with the test car I drove the other day.
    This flaw turned a very impressive car into one we could not own.
    The brakes were very over-assisted. It seemed to require less than half the pedal pressure to achieve the same amount of braking I am used to and I have driven a lot of cars over the years. This led to the brakes being hard to modulate coming to a complete stop resulting in feeling slightly ill when the car grabbed to a halt repeatedly.
    Despite driving it as carefully as I could, I achieved only partial sucess but my wife was totally unable to stop smoothly and she was unable to agree to wanting the car.
    I did a search on these forums the other day and found only one person mentioning the brakes feeling over-assisted. Google found nothing else.
    So, to all those proud 118TSI drivers, did I drive a typical car or a bad one?
    Also....... anyone know if any master cylinder valves etc can be changed to make it easier to drive?
    Thanks in advance,
    Steve.
    Feb 2009
    NSW
    Yep. They are all like that. A major flaw in my books. I still can't drive it smoothly! They grab too quickly and with differing pressures too. I find I brake early and coast to the stop, then it's ok. You can judge it better/ make it smoother at lower speeds. My GF has the same complaint.
    Jan 2011
    Brisbane - QLD
    My wife had a Mk6 118TSI before... with regards to the brakes, it depends on what other cars you're comparing it to. If compared to Japanese cars, the Golf's brake pedal is obviously shallower and you can feel a lot more bite with little brake pedal travel.
    The Mk6 GTI brake is similar. So, if you think the Golf is for you and you like it, then i think you'll get used to the brake after a while.
    Dec 2010
    The one I tested drive (118TSI) and loan car (TDI) was bit over as well.
    But my 118TSI is fine, just like normal.
    Maybe dealer could help to reset the break setting in ECU !?
    Feb 2009
    Sydney, Australia
    My MKV Golf GTI also had brakes such as the OP describes. However, I quickly adjusted to them and then came to prefer it - you just had to remember to give forward-warning to anyone else who may get into the drivers seat to have a go.
    My Polo GTI was about half way between previous Toyotas and the Golf.
    My Golf 6 seems about the same as the Polo, but with much better feel at the limits of its braking. Maybe it too would be a shock for the OP to drive and I'm just used to it now that it isn't even noticable anymore...
    As for never seeing anyone talk about it - it has been mentioned in several threads here, just no one had created a specific thread about it.
    I've also seen it mentioned in a few motoring reviews - but no one had gone so far as calling it a major design fault or saying that it's dangerous etc.
    Jan 2010
    Springwood
    I don't notice it as much in the R as i did in the Polo (9N),
    light pedal use hardly slowed the car, a little extra and you pull up quite aggressively.
    Perhaps the additional weight of the R isn't as easily influenced by the more aggressive stage.
    (I'm also driving it more aggressively so i'm prepared for it)
    I recall someone mentioning that the VW brakes trigger the rears first to improve stability?
    this seemed to explain the behaviour, light pedal use only engaged the rears.
    After a period of time, i ignored the first braking stage, and treated the 2nd stage as the take-up point.
    this seemed to be smoother, but it was still difficult to modulate as well as i can in other cars.
    2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
    Oct 2009
    Como, WA
    It caught me out a couple of times, but after almost a year, I'm used to the sensitive brakes. Now when I hop into my daughter's Barina or my wife's Pulsar... woah! Heavy braking required. As for my son's Camry, I think they forgot to hook up the vacuum assist.
    There is no way that I would regard the Golf's brake sensitivity as a "major flaw".
    MY10 Golf MkVI 103TDI United Grey
    Dec 2008
    Sydney/Canberra
    Same old story...
    The brakes aren't over-assisted. You're just not used to having a car with brakes that actually work effectively.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Oct 2010
    Melbourne, VIC
    No way. They are over assisted compared to other cars - sensitivity has nothing to do with braking efficiency.
    There have been a fair number of posts about the MkVI TDi having over assisted brakes - from those posts, I thought that it was an issue limited to the TDi.
    Sure, you get used to the sensitivity if you ONLY drive the Golf but when switching cars, it is a pain.
    Strangely, given Mr Bob's experience, I find my 9N3 has a very normal pedal feel - but maybe the R has a more progressive brake feel.
    Nov 2009
    My GTI's brakes are very heavily assisted, and I notice a significant difference when switching between it and the two MkV FSIs I drive. A mate drove my car a few days back and took some time to get used to the pedal pressure required. No question, they're touchy. I am used to it myself now, and don't have any issues dialling up the right pressure smoothly.
    I've also heard that rear discs are routinely changed at 30,000km? And the fronts not long after? Coming from Hondas that (normally) go through discs in 100-150k, this was a bit of a shock. And don't get me started on the brake dust...
