Results 1 to 4 of 4
Thread: Oil temp sensor fault
    Jul 2013
    Vic
    Hey all new golf owner here and the screen has flashed up a fault saying oil sensor: workshop. Have had mechanic scan fault codes and it has come up saying the oil temp sensor faulty. Having trouble finding information on location and a part number. As my nearest vw dealer is 2 hours away was going to source the part my self and have mechanic install it as he doesn't do much work on the vw. Any help would be greatly appreciated.
    Mar 2013
    Brisbane QLD
    The oil temp sensor is the same one that is oil quality and level... have a look at the bottom if your sump.. you will see the sensor there....VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Luckily they are pretty cheap. Do an oil change and replace the sensor at the same time.
    Obviously check the part number matches before buying anything:
    VW Sump OIL Level Sensor 1J0907660B MK4 Golf Passat ETC | eBay
