Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Oil leak Mk6 GTI
    Jan 2012
    Did my own easy as except changing the plug and wire connectors. Take your time on getting the old plug off. Should be 30mins job if that. Bought mine from main steelers without the plug as they say there were none in Australia, kindly was given a plug by Lucas_R. ECS is your best bet and buy 2 new connectors just in case.
    2015 Golf R. Lapiz Blue.
    Erskineville, NSW
    I had / have a leak from the same area - hopefully now fixed.
    I pulled the magnet assembly yesterday and you can see that the o-ring has flattened. I assume it has been heat affected after 150,000km as there are no moving parts.
    The original unit doesn't have the mounting plate fully welded to the magnet - there are several long gaps which allow the oil to leak through if the o-ring is weeping. While there is a revised unit that acts as a secondary gasket, I think you can fix the leak using the original silver unit (if it's working).
    Tools required:
    T30 Torx
    and whatever else to gain access & drive the torx. I used a 1/4" drive apex bit holder & a 1/4" drive ratchet.
    A screw driver or wide blade to assist levering the magnet out
    A pick to remove the o-ring (I use a 90 degree scriber)
    Parts required:
    o-ring 52 x 3 (mm). This is from VWs' spec and I forgot to measure it but convention is ID and x-section. The original VW partno is N91000101 but possibly that's superseded by WHT007212. I don't know what insane price they are locally but they are about AUD5 overseas. You'll probably find a local bearing place stocks something for less than a dollar. Generic 52x3 o-rings are on ebay for 10 for $3.
    Some type of liquid gasket. I used Loktite 515 Master Gasket because I had a 20 year old tube on the shelf but any generic "form-a-gasket" or "gasket-maker" silicone, RTV type product will work.
    Some metho, degreaser, petrol, etc to clean all the oil off the mating surfaces.
    Some fly wires / electrical probes to test the magnet.
    What to do:
    disconnect the electrical connector
    push any hoses out of the way
    undo the 3x torx screws - give them a clean.
    Pull the dipstick mount away from the engine about 20mm
    Pull the magnet assembly directly out. You may need a wide, flat blade to jolly it along if you have no finger-nails but it won't be super tight.
    Clean all the excess oil out with a clean rag.
    Remove the o-ring - clean the o-ring groove with clean rag. Maybe use the pick to get right into the corners.
    Lubricate the new o-ring and fit it to the o-ring groove - any lube will do - Petroleum jelly, bearing grease, engine oil, etc.
    Give the general area a smear of lube too.
    Clean the magnet assembly
    Connect the flywires to a 12v source (car battery) and touch them to the terminals on the magnet assembly. The piston should come out instantly & fast. If it's slow then use some solvent to clean the internals - there's a small square opening next to the piston. You can grab the piston with your fingernails and actuate it manually to pump out the gunk.
    Refit the magnet assembly
    Run a small bead (2mm diameter) of sealant in the angle where the magnet is welded to the mounting ring (the thing with the 3 holes). This will act as a secondary gasket to the o-ring and seal up the gaps in the assembly.
    Put a thin smear of lubricant on the outer body of the magnet about 10mm wide to help the magnet get past the o-ring.
    Fit the magnet assembly to the engine. You have to be dead straight onto the o-ring. Give it a wiggle & a bit of pressure and it should pop straight in.
    Replace the 3 torx. Don't forget the dipstick mount. They just need to be nipped up - probably about 20Nm? You'll know how much force it took to undo them.
    Clean of any excess sealant - having blobs of it hanging out the side looks unprofessional & doesn't assist in sealing. I use a satay stick with the end cut to a chisel point to remove excess gunk.
    Reconnect the electrical connector
    Reposition any hoses you moved.
    Give the sealant 30m to gel (read instructions)
    Start car - road test.
    Check for leaks after a few trips.
    While you have the sealant & tools, check the cam position sensor on the front of the engine just to the right of the oil filler cap. The o-ring in them tends to leak as well but VW don't sell them.
    Same process. Remove, clean, bead of silicone in the angle, refit, remove excess.
    Aug 2016
    Suburb, State
    Reviving an old thread in order to thank brad for sharing his fix in such a detailed manner and also thank Lucas_R for the info on the new part. I recently bought a B6 Passat and I just found a leak on my camshaft magnet. And now I know it is an easy fix. Thank you, brad and Lucas_R!
    Last edited by AstroAvia; 01-03-2017 at 09:14 PM. Reason: I tried adding a link to the parts. It did not work though.
    Jul 2013
    Ah crap i better check my car. Have yet to even look at the dipstick...
    Dec 2010
    Mine was leaking after the first service. Was suppose to know yours take this long to leak. Mine has to be fix twice to stop the leak.
