Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 97
Thread: The Official VWW VCDS Tweak Library
  1. #31
    5. Disable DRL's (Daytime Running Lights)
    1. Navigate to 09 - Central Electronics - Long Coding
    2. For vehicles with Halogen (stock) lights go to Byte 15. For vehicles with Xenon lights, go to Byte 11.
    3. For Halogens, toggle Bit 6. For Xenons, ???
    Just VCDS my car
    Byte 11 - Uncheck Bit 2
    This turns off xenons light as DRL, all lights off when switch is set to 0
    Byte 15 - Check Bit 6
    This turns off xenons light as DRL, auto turns on lights when dark, switch set to AUTO
    Sold - Nissan Silvia S15 JDM
    Current - VW Golf GTI MK6 (Candy White, 5-Door, DSG, Bi-xenons, RVC)
  2. #32
    Apr 2010
    Nov 2009
    I went though the R again and the only thing we can change it seems is "Rain Closing Active" which I assume is the auto closing sunroof/windows when rain is detected.
    Corey you found anything else?
  4. #34
    Feb 2009
    Sydney, Australia
    Lol... I seriously haven't even plugged in my cable yet! I'll have to get to that one of these days...
  5. #35
    Apr 2010
    Maybe you could shoot Dana @ Ross Tech an email asking about what tweaks are available/missing on the latest model R?
  6. #36
    Nov 2009
    Actually I need to follow that up as I sent Dana a few debug logs for the R a while back.
  7. #37
    Jan 2009
    brisbane queensland
    I am just about to plug the vcds into my R and see what i can play with just hope i can mess around with as much as i could with my gti :S
    YAY I got my R!!!! White, recaro seats, 19" wheels, bluetooth, reverse camera
  8. #38
    Betoota
    Can anyone confirm if the dimming of the DRL on the R can be changed under DRL Byte 24?
  9. #39
    Dec 2010
    Deep in your subconcious
    Feb 2009
    Sydney, Australia
    The license to you VCDS is attached to the cable. I can't see how the use of that ebay cable would be of any use, unless you illegal use VCDS
    Anyone else know what the situation is?
