Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 97
Thread: The Official VWW VCDS Tweak Library
  1. #61
    Aug 2011
    vic
    Do you know the code to put up all the windows upon locking the car (one press)?
  2. #62
    Apr 2010
    No, I just hold down the lock button and the windows will close.
  3. #63
    Aug 2011
    vic
    Found it
    (Vag-Com / vagcom Guide - Page 17 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com)
  4. #64
    Apr 2010
    Thanks - I've added it to the first page. I like to use the remote to adjust the windows to a certain height on warm days when at home so I won't personally use it.
  5. #65
    Dec 2010
    In the first post of this thread, it says...
    The HEX-xxx-CAN interface supports most VW/Audi group cars. It is more expensive as it supports the widest range of cars and unlocks a couple of extra features in the VCDS software.
    Does anybody know what those extra features are?
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
  6. #66
    Apr 2010
    The main ones are that you can erase all error codes from all the control modules in one go, whereas in the cheaper one you have to go to each module individually to remove any error codes (might save you up to 5 minutes).
    The other is that when logging data while driving, the sample rate is faster with the more expensive cable (i.e. you get more data in smaller time intervals).
    See here for more info, or use the Contact Us link on their website to ask them directly.
  7. #67
    Oct 2010
    Stoke on Trent, England
    Convenience Features/Tweaks
    Has anyone tried this mirror lowering in reverse rear on a mk6 Golf? I've had a look but I can't see Bit 3 in Byte 4.
    Golf GTD (170) 2010, 5 Door, Shadow Blue, Flat Tyre Indicator, Service Plan, Basic Protection Pack + VCDS.
  8. #68
    Nov 2009
    Quote Originally Posted by Keithuk View Post
    In Australia, this function is only available on GTIs/GTDs/TSIs with the Park Assist option. Otherwise the car is missing the necessary controllers.
  9. #69
    Apr 2010
    Yeah you can tick the box (I have) but it does nothing since we don't have the hardware for it. I just set both mirrors to respond simultaneously to adjustments (the the knob is pointing to R), and then quickly lower both mirrors in one go while engaging Reverse gear with my other hand.
  10. #70
    Oct 2010
    Thanks guys well I can't see that option on my UK GTD. The terminolgy doesn't look right Mirror lowering in reverse rear the reverse rear part.
    Thats a bit over the top Ryan thats a useless feature anyway adjusting both mirrors at the same time, mine are set on individual.
