Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 141 to 150 of 154
Thread: The Official Mk6 Golf Seat Thread
  1. #141
    Oct 2014
    It is possible to retrofit the heated seats.
    Wouldn't be a cheap exercise I wouldn't imagine but certainly not technically too difficult.
    Check this guide for general info:
    How To: Mk5 Heated Seats Retrofit - page 1 - How to Guides / Troubleshooting - MK5 Golf GTI
    This is for the Mk5 Golf so the pinout to the CECM will not apply (there should be info on connection to the newer BCM somewhere but I haven't looked)
    There may be a small market for your cloth seats for someone wanting to spruce up a lower model Mk5 or Mk6 particularly at the right price...
    Yes, you can.
    I did it in my Mk 6 Golf by getting some second hand leather seats (which all have the heating elements in them). The 2007-8 Mk5's had a wiring update so the later Mk 5 is the same as the Mk 6 for wiring and plugs on the seat side (means you could potentially use R32 seats). I also needed the wiring loom which i got from Kufatec (**** instructions) and the switch for the dash (in my case the climatronic unit with heated seat function).
    Used leather interior should be about $400 for a standard golf and about $1,000+ for a nice golf R leather interior
    wiring loom $100
    climatronic switch $50-100
    You need to turn the function on with VAGCOM and you'll need the wiring diagrams in the electrical manual i posted a link to in the Manuals forum. It's a pain in the butt to do but I honestly don't know how i lived without it now. Heated seats are amazing.
    Retrofitting it into existing seats would be more difficult if you use OEM parts but possibly cheaper if you do the hard work. There are also some after market kits which utilise the buttons near the gear stick.
    EDIT: You will have no problem selling your fabric seats. I managed to sell my crappy comfortline seats for $200 because the airbags have value.
  2. #142
    Oct 2014
    Here's a set of Mk 6 GTI leather seats for $800. They look almost identical to the R seats but for the "GTI" label on the head rest. You can't see the peak of the side bolster or the bottom of the front seats where they wear out first but they look in ok condition.
    Leather Interior Golf 6 GTI in VIC | eBay
  3. #143
    Aug 2016
    What rear seats will fit in a MK6 R?
    Hi guys,
    Managed to upgrade my fabric front seats to leather, now I need to find some rear leather ones to match. Can anyone clarify (and please be certain) which seats will fit? Just MK6 models or will MK5 and MK7 fit also.
    On a related note, if you know of someone who's selling or where to get them, please let me know.
    Thanks
  4. #144
    Mk5 R32 will fit AFAIK and I have a set in Perth
    Sent via courier pigeon
  5. #145
    Mk5 and Mk6 are interchangeable as both cars share the same chassis. I doubt the Mk7 seats would bolt in without modifications.
    If you already have MK6 leather front seats then you should try to find Mk6 leather rear seats so that they match (the Mk5 seats are a slightly different shape/pattern/design to the Mk6).
  6. #146
    Aug 2016
    Thanks - do you know where the best place to look would be?
  7. #147
    Oct 2014
    Quote Originally Posted by Biggless View Post
    I got mine through wreckers here in Sydney. In 2007 VW updated the seating in the Golf Mk V and kept that config all the way through the Mk6. Late Mk V and early Mk VI Golf the seating was very similar if not the same with limited colour combo's. GTI and R seats are different from the TSI/TDI seats, at least in the front. You might struggle to get back seat only from a wreckers tho. They only wanted to sell me the whole interior. Mind you that was a whole TSI interior for under $500.
  8. #148
    Jul 2016
    Front seats have no power
    Hi guys,
    Had my car for almost 2 years, MK6 2011 Golf R and around 12 months ago my front seats stopped working after a service. Both sides, lumbar and heating. I had my mechanic check all the fuses last visit but he found no fault.
    Anyone have any idea where I should look next?
    Thanks!
  9. #149
    Get a multimeter and a wiring diagram and start belling your way through to find where the fault is.
    Check to see if dc supply is available at the seats electric motors, if supply is available then you probably have a stuffed motor
    Sent from my D6653 using Tapatalk
  10. #150
    Check to see if supply is available at the Electric motor first
