Page 38 of 57 FirstFirst ... 28363738394048 ... LastLast
Results 371 to 380 of 566
Thread: The Official Mk6 Golf DSG Clutch / Shudder / Squeal Issues Thread
  1. #371
    Apr 2010
    More likely that the lack of downshifting is associated with the adaption process Normally it doesn't downshift down hill unless you touch the brakes (which obv kills cruise controll)
  2. #372
    Mullaloo, WA
    Have to say that mine is also downshifting on hills ( to 3rd ) and also shifting at higher revs ( not hitting 7th gear until i have hit 75-80kph ) since they did the update..... But yeah could simply be that I hadn't driven hilly areas as much as I have since the update.
    MY14 Audi S3 - Misano Red, S-tronic, Performance pack with parade red trim.
  3. #373
    Quote Originally Posted by Candyman View Post
    I got me some of that 37g7 last night
    Haha well done!!
  4. #374
    Jan 2010
    State of Denial
    I don't think gavs is right on this one - mine is still downshifting to hold speed going down hills on cruise control two weeks and over 800km after the reflash. Like the new feature!.
    2018 Tiguan 110TSI Comfortline + DAP
  5. #375
    Apr 2010
    How steep is the decline? What speed limit is the road?
  6. #376
    Aug 2009
    Melbourne, Vic
    I am inclined to agree. My car has never downshifted going down hill since the day I bought it. I have poked prodded & rooted around with my DSG7 resetting adaption counts and other things with VCDS quite frequently.
    Then last month VW re-flashed both my ENG & DSG software with latest firmware after fitting a new motor for good measure. Now it most definitely downshifts going down hill with the CRZ control set and does a reasonable job of holding the set speed. Never did any of that before.
    Although, as my DSG7 had not been touched by VW since 2009, it is possible there was a update in between that I missed, which added the downshift feature.
  7. #377
    Canberra
    My car used to shudder on 2nd quite violently. Had it serviced with a VW specialist (not dealer) and the shudder got reduced to like 20% of what it was. I can still feel it sometimes but only slightly, and not as often. I'm still puzzled at why the shudder would disappear like that when it was a minor service and not at a dealership.
    Quote Originally Posted by logger View Post
    I've got an MY11 118TSI DSG7 and got a DSG software update last April 2012 that changed my shift points.
    This was it, 37G7: http://vorsicht.org.hk/forums/showthread.php?t=12728
  8. #378
    Jul 2012
    Bendigo, Victoria
    Quote Originally Posted by ziggyboy View Post
    This was it, 37G7: 37G7 DSG 7 software upgrade - VORSICHT Hong Kong
    Had the same thing after 37g7 update. Had been meaning to get back to dealer to have it checked but in meantime over about 6 weeks had improved about 80% also. Still getting occasional 2nd gear standstill starts but much reduced shudder. Figured it must be the fuzzy logic that done the job. Hoping it stays the way, or better still, improves even further.
    MY 09 JETTA 118 TSI 7 spd DSG
  9. #379
    Brisbane, Queensland
    Mine is the same, never downshifted and is more than happy to greatly exceed the set cruise speed when going down hill. It always annoyed me as I'd end up way over the speed limit.
    I have a 118TSI which is in for its 30K service today and is getting the software upgrade for the DSG. I noted it said 7spd DSG recall on the paperwork. I haven't picked the car up yet so can't report on the results.
    We have a Polo GTI and it does downshift going down hill when cruise is on. It's been interesting to compare the two cars. Obviously the GTI has a lot more power but the gear changes are very different.
  10. #380
    Apr 2010
    I wouldn't call 12kw a lot more power (although weight difference will have a bigger impact). Get Stage 1 for the Golf and they'll be more evenly matched.
    My car never downshifts unless the brakes are touched, but it generally will only go <5kph over set cruise speed, if I see a descent coming up I'll just tap the 'Dec' button a few times to compensate.
