Page 57 of 57 FirstFirst ... 747555657
Results 561 to 566 of 566
Thread: The Official Mk6 Golf DSG Clutch / Shudder / Squeal Issues Thread
  1. #561
    May 2019
    Perth
    Your warranty should cover it. I paid $2500 for a new clutch pack, it’s a 2011 tsi, just over a year after, it’s started again
  2. #562
    Oct 2019
    Debating whether to persist with this car or not. My mk6 118tsi has been bloody awesome. Last year VW replaced my mechatronics after the car died in the middle of a busy road at speed under goodwill. that was for a 2012 car with almost 180000km on the clock. Before that and now continuing after i have the shudder when changing to second gear or accelerating from low speed. not every time but often enough. I know i'm probably in for a clutch replacement but it's been doing it for 2 years now i'd say. I wonder what else it has damaged in that time.
    Hard to choose whether to try and trade it in now, wait for a failure or fix things preemptively. 189000kms now and otherwise I love it.
    I had so many dreams to upgrade the lights, stage 1 tune it etc but i'm scared it will blow up in my face as soon as i do.
    2012 MKVI Golf Comfortline 118 TSI
  3. #563
    Dec 2020
    Queensland
    Hi,
    I see this post has been going for more than 10 years but I fail to find a resolution to the problem or perhaps mines a bit different?
    I have MK6 118TSI 7sp DSG 155K kms ODO and developed shudder in gear 1 several months ago. From minor shudder between 1st and 2nd gear it progressed to several incidents of full or partial gear drop to D (from D1), while raving on its own (even if I switch it to N) and few incidents included loss of power steering, break pedal stuck and no acceleration, all of which happened at cross lights / middle of crossing. Note to say it’s occurring intermittently, but lately it’s my daily bread and 90% of it it comes up when I am standing at lights (4 beeps, break light indicator on and off we go). Yesterday, I got engine light on as well, which disappeared on a drive back from work but I can only picture it flashing at me again soon.
    Virgin last three months:
    Three visits to AutoLeaders-> found everything else but anything to do with this. Issue not resolved, I gave up on bringing it back.
    Two visits to VW Southport, first time they said some electric box / wiring melted and needs replacement as if that was the cause (it wasn’t), second time they did firmware upgrade on “mechatronics?” (No improvement) and then suggested clutch replacement ($2600). Obviously charging me both times.
    Reading through the forums, I understand few people have replaced the clutch but I fail to find if that was a permanent fix or if it only buys me another X amount of kms on the car? Is the clutch simply worn out or has there been some fault rectified in the clutch replacement?
    Seeing that the shudder issue on DSG has been going on since 2009, has it been recalled? Mine is 06/2009 so I assume my chances of getting it fixed through recall would be slim anyway due to 10 year mark, right?
    Seeing it’s 11 years old, 155K kms and the car is ok otherwise, is the clutch replacement even sensible? I would hate to spend extra 2-3K only to have this issue half year later again.
    Thank you for advise.
  4. #564
    Aug 2024
    Canberra ACT
    I have a 2010 Mk6 GTi DSG (DQ250 with code LTL) with a shudder on all up changes and bangs on the way down. Same in manual mode. Quoted 6K to rebuild box with new clutch pack, solenoids and flywheel. Was told I would need an identical DSG with code LTL if wanted to replace with a second hand unit. Can anyone confirm this is legit or whether there are other DSG codes that would work on my car.
    Any advice appreciated.
  5. #565
    Dec 2016
    I had the same symptoms with my DQ250 at just over 300k KM, my mechanic changed just the clutches and the DMF. Including labour and fluids it was around $3,800 but now the shifts are as good as new.
    Did they say why they wanted to replace the solenoids or rebuild the box itself? Seems excessive if just preventative maintenance.
  6. #566
    Aug 2024
    Canberra ACT
    Thanks for the reply. They didn't say they wanted to rebuild just replace solenoids, clutch pack and flywheel. Mine only has 150k on the clock and the DSG was serviced at 120k.
