First experienced the shudder yesterday on my car (just reached 40,000 km). Should I book it in now or wait until it does it all the time? Concerned that it won't do it when I take it in. Anyone had their clutch(es) replaced by Denlo Parramatta?
When did you first have the problem? If it was just before 30,000kms, then you'd have to wait until you reached ~60,000kms to confirm if the problem was properly fixed or if the clutch replacement is a workaround. Are there any differences with the replacement parts compared to the original ones, etc?
MY09 118TSI - SOLD
You could ring up just to let them know, but they probably won't do anything until one of there guys experiences the problem for themselves while they're with you on a drive.
I just took mine in for it's 45,000km service at Baroworld Mascot this week. Went on a road test with one of the mechanics. I was told that they were going to do a software update first, let me drive it for about 500km and see if the problem comes back. If it did then they would look into the mechanical components.
But when I went to pick up my car they told me they had already ordered a clutch pack and booked my car in for 2 days to get the new clutch pack installed (under warranty).
I too was concerned that I would not be able to demonstrate the shudder, but I discovered that it get's worse the longer I drive the car. So I just drove around for a while before taking the car in to the service centre.
Wangara VW want me to bring the car back for further investigation.... will do that and hope that they will have a fix for it as I have had the DSG re-flashed a few weeks ago at the 15k service.
MY14 Audi S3 - Misano Red, S-tronic, Performance pack with parade red trim.
I was driving the family golf VI tsi (the base model), and I found the clutch seems to occasionally "shudder" as though the electronics are sending conflicting signals to it.
It happens usually when you've come to a standstill more or less, and accelerate slowly.
Actually it seemed to happen also when stepping on it a little from standstill.
And I was surprised that in slow heavy traffic, it's quite rough when it engages and disengages.
Not overly rough, but defintely enough to bother me.
I've had a fair bit of experience driving an S3 with the 6 speed DSG, and I find that almost perfect.
Is this a common complaint with this car?
It has done 20,000 k's btw, and is about 18 months old from memory.
If you'd have searched you'd have found this thread http://www.vwwatercooled.org.au/foru...ear-45873.html
Actually it's only 6 or 7 posts below yours on the same page mate.
GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
thanks i'll have a read of it, though this appears to be from a stand still (effectively neutral), to the actual engageing of D1, not D2.
Maybe still the same issue though
Seems like a lot of you are having this problem with the clutch pack. My suggestion is to refer to your dealer's service center, they will normally carry out a basic settings on the clutch adaption and a specific road test. A request for a set of new clutch packs can only be send to VW after this is done and when the problem still persist, even after a few months without issue.
Disclaimer: I act here on my own thru my personal experience and not on behalf of VW or the VW dealership I work for.
