Yeah, although the 7spd seems to be fine with the 320nm torque of the Stage 1 Upgrade. Those common clutch shudder issues are completely unrelated
The 7-speed dry clutch is used in low-torque applications of typically 250Nm or less (its claimed maximum torque capacity). VW, Skoda, Audi etc fit that gearbox to 1.8 TSIs from memory.
(The 6 speed wet has a claimed max of 350Nm, hence why it's used in the performance kit and torquey diesels.)
Just to clarify, I'm not insinuating that the torque load is necessarily a factor here. VW will torque-rate a gearbox with a ton of headroom to cover off mechanical abuse (thrashers, lack of servicing / oil changes if required) and gearbox life expectancy.
There are plenty of people pushing 550Nm+ through the 6 speed without problems. I wouldn't recommend that myself, but if you only want your gearbox to last a short time...
lol, just having a joke
The mech told me that they do the mechatronic only if you have problems (ie surging, loss of power, hesitation, general weird shifting) AND if you actually request that some diagnostics are run as the replacement is a $$$ job.
Just had the 30k service done and the shudder in 2nd (but also sometimes in 1st) was mentioned. As a result they have ordered replacement parts from Germany and will advise when they arrive.
I'm guessing it was the clutch pack - it was picked up by the wife and she doesn't recall exactly what part they said. I'd imagine it should be noted on the service report.
Got the car back today, lucky - I guess.
2 years old 118TSI DSG, Comfort-line, had everything replaced, from engine, air-cond, clutch pack, mechatronics ... a perfect car now.Just spoke to the fleet to get a payout quote to end my lease and sell the piece of junk.
$28k - anybody?
---------- Post added at 03:43 PM ---------- Previous post was at 03:40 PM ----------
I've got my car back today. It drives exactly the same as it did before the mechatronics replacement, nowhere as close to the Jetta I mentioned above. Meh!
I've just dropped my car off at the dealers to take look at the gearbox (DSG) specifically. I have 3 niggles / compliants which I hope they look into. I believe in one form or another, they have been mentioned on this thread.
1. 2nd shudder (not always but enough to be annoying)
2. 3 gear bag of bolts (this is what I'm calling it. When the car automatically downshifts into 3rd, i sometimes get a grinding (think nuts and bolts in a glass jar noise) noise - this cannot be good right?
3. Failure to consistently kickdown (if I'm in 4th at say 50kmh, i floor it till i hit the button in the firewall, nothing happens other than it just speeds up in 4th - no downshift whatsoever. This has caught me out too many times and now a real safety issue).
