Originally Posted by
minke
Gavin - Thank you for your input.
I assumed that resetting ECU would reset all values.
I assume the dealers checked the fuel trims. It's interesting to note that when I have instant fuel economy displayed and get out of the throttle it takes a long time before it displays 0.0L/100. My friend's GTI did not exhibit this delay .
I can think of two examples on high (what I think is high) oil temp.
* Sydney to Wollongong with an ambient temp of 13 degrees the oil was reading 106-107 at 110 in 6th gear cruise control
* Inner Sydney to Parramatta (lunch with a friend) then Parramatta (via M4) back to inner west. Great traffic flow, no lights run. 108 degrees. I think ambient that day was 15.
I wonder if the 'oil temp' is related somehow. Modern cars will fuel the cylinders to aid cooling. If the car thinks it is hot, it might be dumping extra fuel for cooling. I know many a modern car does this now so I would assume the Golf has that programmed into its ECU
