Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Noisy tyres.........or something else????
    Mar 2011
    Dull thump thump thump which increases in frequency with wheel speed. Very noticeable at low speeds e.g. 40kph and also there (at higher frequency) as speed rises. No vibration through steering wheel or anywhere else. Seems worse when boot loaded. Purchased new 09 build GTI 5-door DSG now 30,000 kms. This noise has been there for ages. Did not have any such noise with Mk 5 GTI over 60,000kms. Dealer confirms definately tyre noise, one or more "feathered". Not apparant to me on uneducated look and feel. Standard rims and original Bridgestones wearing well and evenly. Am I going mad??????
    Apr 2009
    Quote Originally Posted by J Walter View Post
    I have exactly the same problem with the same tyres. Mine is June 09 build with 44,000kms. I am going to ask at next service (3 weeks) about wheel alignment. Anyone recommend a good wheel aligner in south west Sydney? The noise is very annoying, I prefer to drive my daughters 8 year old MK4 at the moment. I have done 2 wheel rotations and have experimented with different pressures all to no avail.
    Are yours 17"?
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
    Jan 2010
    Springwood
    If it's not tyre related, it sounds like a wheel bearing...
    Surely not on such a new car though?
    Ozram, I have used gordon leven in penrith area... Might be a bit far for you though
    2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
    Feb 2009
    Gold Coast, QLD
    it will definatelly be the tyres, ive got 225/40/18 tyres and they went after about 35-40k done on them. sound was very annoying, very noticable at slow speeds especially when slowing down and was a constant whine at highway speed. chaged the tyres the other day and noise has gone completely, and yes it was due to 'feathering' - get a wheel alignment when you change your tyres, im going to get one any day now - just trying to find somwhere cheap - quoted at $120 by Pedders atm :| (all 4 wheels).
    sound i got was more of a deep whine though at slow speed and higher pitched whine at higher speed.
    MY18 MKII Tiguan 162TSI R-Line | Deep Black | DAP | Sunroof
    For Sale - MY11.5 MKVI 3DR Golf GTI | Pearl Black | Manual | Sunroof | Dark Tint | Dynaudio | MDI | Bluetooth | Bi-Xennons
    Mods | R Tails | P3 Gauge | LED Interior Conversion | Lakin Plates | VW Racing Springs | 19" RAYS 57Motorsport G07EX
    Mar 2010
    I would also suggest getting a 4 wheel alignment. I recently got one done by Kmart auto for around $70
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
    Mar 2011
    My wheel alignment is OK and tracking and tyre wear is good, and the wheels are standard. Thanks for the info guys. I am now persuaded that it is the feathered tyres and won't be fixed until I replace them. Any suggestions for replacement tyre brands? You may be wasting your money on a wheel alignment Ozram. If you can put some other wheels/tyres on and see if the noise goes away. My dealer said he did that with mine and the noise went, but I was not sure I believed him. Maybe it was the truth!!!!
    Feb 2009
    Gold Coast, QLD
    the noise wont go away with only the wheel alignment done alone, worn tires will need to be replaced also. getting the wheel alignment done will just prevent the same happening to your new set of tires. my tyres were worn only on the inner loop, rest of tread was fine! thats my understanding of it anyway
    Are you sure it's not a bolt/nail embedded in the tread? Not always obvious from just a simple inspection.
    Open your windows, drive slowly in a quiet place - see if you can narrow it down to one tyre. Then have a good look at that tyre.
    Nov 2009
    Check out the http://www.vwwatercooled.org.au/f112...ead-28107.html - loads of good info in there.
    Erskineville, NSW
    My wheel alignment is OK !!!!
    How do you know that your alignment is OK?
    Try swapping the tyres left to right so that the direction of rotation changes. Even better if you can go front to rear at the same time.
    Increase the pressures to at least 36psi - 38psi is better still. Give it a few thousand km & you might find the noise will reduce a bit.
    I find Bridgestones to be generally quite resistant to saw-toothing & Dunlops are usually shockers. Either way, I always prefer to pay a bit extra & fit Michelin.
    For ongoing maintenance, you should be cross-rotating your tyres every 10,000-15,000km.
