Results 1 to 10 of 18
Thread: Noise on cold start
    Jul 2009
    Noise on cold start
    Hi. This is my second post since I bought a 118TSI last July. It's generally very quiet except on cold starts when it's significantly louder, making some sort of a rattle (I wish I could describe this better). The noise disappears soon after I start driving but it doesn't sound right. I think it appeared after about 3 months.
    I took it to Barloworld in Botany (Sydney) and they updated the software said it was fine. It's obviously still there. So what do I do now? I could take it to another dealer, but where? Or should I take it to a reputable independent VW repairer (suggestions please) for an early first service. The car has just done 10,000ks.
    Thanks a lot for your suggestions
    Jan 2009
    blankedy
    I don't know about your specific car, but my VW has a feature where air is pumped into the exhaust system to help warm the CAT.
    It is very noticable in the RPM, holds about 1k rpm for 20-40 sec, then settles at around 800rpm.
    Does this sound similar?
    Jul 2009
    Thanks for the prompt reply. It could be something like that. I'll have to check in the morning when the car is cold.
    Sep 2009
    Quakers Hill, NSW
    Quote Originally Posted by olaf View Post
    Sorta sounds like a diesel, if it's like my 118TSI. IIRC it's mentioned in the manual as the hydraulic tappets pumping up.
    2009 118 TSI
    1980 Bedford van
    2015 Hyundai i30 SR
    Jan 2008
    Sunshine Coast
    direct injection is a bit noisy too...
    Sep 2009
    Melbourne, Victoria
    Mine does this too. I think, as suggested, it is normal and designed to warm up the engine as quickly as possible.
    Cold engine = bad fuel consumption.
    I'm not sure of the technical details - is this "exhaust gas recirculation"?
    Dec 2008
    Perth
    My 118TSI is quite rough on cold start, the idle is a little inconsistent and a bit noisier than usual. I just put this down to the fact these engines are finely tuned compared with your average 'Genfordyota' engine. Once warm it runs sweet and is extremely quiet on idle, even quieter than a small VTEC.
    MY14.5 VW Polo 81tsi Comfortline - Candy White - Comfort Pack
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by cwcarruthers View Post
    I think you are probably correct, internal exhaust gas recirculation. Because it is "internal" EGR by way of valve overlap, you get the rough running, as compared to the older system that used a dedicated valve between exhaust and intake manifolds.
    Although my understanding it is an emission control strategy. Perhaps to get the CAT up to operating temp asap. I have noticed that exhaust gas temp (VCDS) skyrockets rapidly during this brief period of rough running to something like 650 degrees then drops significantly again, coincident with the return smooth running.
    My car has always done it and I have just considered it perfectly normal.
    Feb 2009
    Sydney, Australia
    Yeah - I think too many people are just a bit anxious about their new babies and strange sounds.
    It doesn't help that they're not really comparable to older cars due to new technologies and new regulations.
    Even 5Litre V10 BMW M5's sound rough on start - almost diesel like, until they're warmed up. VERY different from the sound of most typical Australia 5L cars
    Quote Originally Posted by coreying View Post
    I also find it interesting that people take it to a dealer and then don't believe the answer and are willing to take it to another dealer.
    Is it about worrying about the noise or not liking the noise (ie I want the dealer to get rid of it)
