Results 1 to 5 of 5
Thread: No interior lights
    May 2010
    HURSTBRIDGE VIC
    No interior lights
    The interior lights in my Mk6 have stopped working. Is this likely to be a fuse problem and if so, where is that fuse as I can't find it in the manual? Thanks in anticipation.
    Dec 2009
    Kew, VIC
    The interior fuse box is located in the end of the dash inside the driver's door.
    You have to prise the trim panel off (4 clips, IIRC.)
    The fuse layout varies from car to car depending on what's installed.
    Hi ya going mate, i just had the same problem too. Solution:
    Use a butter knife or a screw driver to pluck the driver side fuse box (There should be a little hinge, allowing for the object to slip through).
    When opening the driver side fuse box, on the back of the cover should be a white fuse puller.
    From the top row, count 4 rows down and it should be the yellow 20amp fuse.
    Hope that helps.
    MY11 90TSI Golf - White Candy, DSG, RCD 510, OEM R taillights, 18" Audi RS-4 with Kumho KU-31,
    May 2010
    HURSTBRIDGE VIC
    Thanks Inception.dln. You are right. When I swapped fuses it popped again so the dealer can sort out the problem.
    May 2010
    HURSTBRIDGE VIC
    Thanks Idle. I can get it off but have trouble working out which fuse it is.
