Originally Posted by
MikeB
In my MkVI, I find the Speedo / tacho quite dim during morning / later afternoon. The pointers are lit (red), but outer circle of dials are dim (in contrast to MFD which is quite bright). Does anyone else notice this?
Obviously when it's dark enough for lights to be on, instrument cluster lights get switched on and it is bright. So I know the lights work fine. But I find it odd there is no lighting during the day.
Anyone else noticed this? I have checked around and can't find any option to leave them on.
Its normal, apparently the car is suggesting that you should switch your headlights on due to the ambient light conditions, mine does the same even if you have the headlights switched to auto. You need to switch your lights on manually if you want your instruments lights to come back on, or just wait for the headlights to come on automatically, (if set to auto).
mk VI GTI, manual, reflex silver, basic
