Page 9 of 9 FirstFirst ... 789
Results 81 to 90 of 90
Thread: New Golf Rs and GTIs will have updated software that can disable ESP completely
  1. #81
    Nov 2009
    Quote Originally Posted by Candyman View Post
    I can't see myself ever using the function actually. I'm no race car driver .....
    I personally think the biggest beneficiaries of this change are journalists who criticise the Golfs for intervening too early and hurting lap times on the track. This'll give the number-crunchers better results with which to compare the VWs against the RS250 and other track heros.
    If my car had the ESP-off I'd only ever use it on the track, and even then only if I was chasing a great time. I doubt I'll end up ever tracking my car to be honest.
  2. #82
    Dec 2009
    Sydney NSW
    Good to hear that you can now switch off the ESP in 2 stages, it gives drivers in the appropiate circumstances the chance to use their cars without the handling characteristics being hobbled by the stability control cutting in.
    No I wouldn't switch off the ESP for on road use at all either, the GTI has enough trouble with wheel-spin as it is.
    mk VI GTI, manual, reflex silver, basic
  3. #83
    May 2011
    NSW
    Has anyone with a MY12 actually tried to turn ESP off completely? I don't think it works on my MY12 GTi.
    I pressed the button once and the display said "ASR deactivated". I then held down the button for more than 4 or 5 seconds and nothing happened. As soon as I lifted my finger from the button, the ASR was activated again. It was as if my 4 or 5 second press was just like a 1 second press - toggling the ASR on and off.
    MY12 Mk6 5 Door GTI | Carbon Steel | Manual | Leather | Adaptive Chassis Control | Bluetooth | MDI | Tint |
  4. #84
    I did on mine, no problem.
  5. #85
    Mar 2008
    Sunshine Coast
    I couldn't on mine.
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  6. #86
    Jun 2009
    Quote Originally Posted by slam View Post
    You press it once for 3 seconds.
    I can't see myself disabling it for road use, does anyone know if it disables the faux LSD as well?
  7. #87
    Mar 2010
    Pretty sure the XDL is always active.
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
  8. #88
    May 2011
    NSW
    Quote Originally Posted by jdimitri View Post
    Ah ha, thanks jdimitri, it is working now. I misunderstood the earlier instruction - I thought when they said "turn it off in 2 stages", they meant we have to turn off the ASR first, then press 3 seconds to turn off ESP.
  9. #89
    Mar 2008
    Sunshine Coast
    That worked !
    Thanks mate
  10. #90
    Aug 2009
    Melbourne - West
    IMO thank fark they done this! There is nothing worse than trying to induce some lift off oversteer to have it cleaned up by the ESP and when on the circuit you dont want it pulling the car back into a straight line when you have already applied inputs to do so.
    Well done VAG!
    APR S2/Whiteline/H&R/Enkei/Carbonio/13.68@101/Winton-1:44.52
