Unfortunately mate the video doesn't sound abnormal at all. I wouldn't be able to justify charging an hour to chaseany noise there.
The manifold runners will activate once started ( like a self check). Based on the video it would appear that your vacuum actuator for your manifold flaps isn't secured and possibly broken. Hence the multiple attempts to activate to verify any concern.
Have you done a dtc check on the engine. Based on what I saw I would expect to see a code logged for either an implausible signal or mechanical malfunction logged for the manifold flaps.
In terms of your Intermit noise. Might seem like a silly question but where do you set your oil level to??
Does the noise happen when engine is both hot or cold but has been sitting for about 30min? If you start the car and it happens. If you were to turn off then start again does it happen again?
-ben
