Results 1 to 10 of 16
Thread: Venting the fuel tank
    Oct 2010
    Melbourne, VIC
    Standard apology if the subject has been covered before and I haven't been able to find the relevant thread(s)
    Does anyone know if the MkVI Golf can have the fuel tank vented to allow additional fuel to be pumped in after it reaches the normal full state?
    I know that the MkIV can do this and my MkVI has a very noticable sloshing sound immediately after I fill it up, so I know there is vent space still in the tank.
    Jan 2007
    brisbane QLD
    why do you want to do this... the vent space is there for a reason!!
    Main Dub:
    2010 Crafter Hanover Bus
    1956 Type 1
    2015 vRS wagon black on black
    Feb 2009
    Sydney, Australia
    Some people like to pump in more than that max and fill the vent space if they're going to be driving long distances immediately after filling up. So for Golf tank is 55L (60 on the R), but you could possibly fit up to another 5L in there if you can vent it.
    But yeah...
    Oct 2010
    Melbourne, VIC
    Diesel doesn't expand and evaporate like petrol
    May 2007
    Jimboomba. QLD
    I've not tried this on my MK6 but on my MK4, if you fill the tank past the first shut off on the bowser nozzle, the fuel gauge gets "stuck" on full and you need to reset it by disconnecting the battery.
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    May 2007
    Jimboomba. QLD
    This is a post from the FAQ area on the MK4 forum.......maybe filling it right to the top is not such a good idea.
    Oneofthegreats
    View Profile View Forum Posts Private Message
    On Hiatis Join Date:Oct 2005
    How long has it been doing it for?
    It may be just an electrical glitch in the instrument cluster. Earlier BMW's had this problem when the owner would fill them right up to the petrol cap.
    This was the fix. Disconnect both the postive & negative battery lead's & bridge the two lead's with a screwdriver or something metallic for a roughly 10 second's or touch the two together if they will reach. Don't bridge out the battery, just the leads.
    This decharges/de-energizises any capacitor's in the vehicles electrical system. It may sound strange but this has fixed many a wierd electrical problem.
    Jun 2011
    Sydney NSW
    All fuel tanks have to be vented, and not directly to atmosphere. Petrol vehicles generally have a carbon cannister, but they can be vented back to the crank case where the fuel vapours are purged through the positive crankcase ventilation. Diesel vehicles will also have some similar system. There is an ADR covering fuel system venting.
    Venting is not just to cope with expansion, but to allow air in as the fuel level falls. On a fully sealed system, the tank would eventually collapse. If you are going to be driving a fair distance immediately, then it is OK to try and add more after the first shut off. If you are just going to try and get a few litres more, then you can have issues with excess fuel spilling. You should remember that the fuel can be quite a few degrees cooler in the underground bulk fuel tanks. Not only are the tanks covered in soil that insulates them, underground tanks are also double skinned with the space under slight vacuum. This is used as an indicator that the main tank has failed if the vacuum in the space disappears. On a hot summers day, you can get a significant expansion of the fuel.
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by craig_the_german View Post
    Doesn't happen IME with my Polo (same venting arrangement as the MkIV Golf).
    Quote Originally Posted by wai View Post
    No arguement
    Venting is not just to cope with expansion, but to allow air in as the fuel level falls. On a fully sealed system, the tank would eventually collapse. .
    No arguement
    Not applicable for diesel.
    Jan 2007
    brisbane QLD
    coef of expansion for diesel is around 9.5x10-4/K
    if your temp difference is 20C between the tank in the ground and in the car then that's roughly 1L for 50L
    but of course you'd be driving away from the servo. But say you fill it up, and park it in the sun, this vent space is there to cater for this expansion.
    The machinery we design at work we usually allow 10% of space in the tank for air for this reason
    Main Dub:
    1956 Type 1
    Oct 2010
    Melbourne, VIC
    Yes, the expansion rate is 0.095% / degrees Celcius, in more common terminology, or about half that of petrol plus the vapour pressure is negligible vs petrol between 0 - 70 degrees Celcius hence the minimal requirement for vent space (unless someone was to absolutely fill it to the brim and then immediately park the car for several hours on a 40+ degree day).
    Now that we have got that discussion out of the way, can anyone answer my original question?
    A simple "no that is not possible" would be sufficient if that is the case.
