It's the first time I've used DSG - and while it's a bit unusual and different to the Mazda3 I came out of and had instant acceleration, once you train yourself in the fine art of slightly hitting the accelerator after the brake, it's a good unit - plus it helps with manual tiptronics.
Currently driving 2014 Jeep Cherokee - looking at the 2017 Tiguan 162TSI Highline (Habanero Orange) !
just a query here.....
the ability to disconnect it's clutches when no engine effort is required. This occurs when the brake pedal is depressed (e.g. at stop light) and also when driving on a straight road when no pedal input is detected. When braking the clutches do not disengage unless the car is at a complete standstill.
The fuel injectors are also cut when no pedal input is detected also saving fuel. It is easy to see when you have the "instantaneous" fuel consumption figure in your MFD showing - it will be 0.0 when you take your foot off the pedal whilst moving.
If these two things happen at the same time... clutches disengage effectively putting it in neutral AND fuel injectors cut....
wouldn't the engine stall???
1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
Yeah - when I read that at first I got all confused over it too. I guess it depends on terminology (which I'm not particularly sure what it is). Like when you put your foot on the clutch pedal, is that engaging the clutch, or disengaging it?
Anyway, I think what he means is that the DSG, unlike an auto, can do the same thing that a person driving a manual can. If the car is in gear, and foot isn't on the clutch pedal, and you're 'coasting', as long as the revs are high enough the fuel supply can be turned off because the motion of the car is enough to turn over the engine, thus using 0 fuel.
The live fuel economy meter supports this. If you lift your foot off the accelerator when moving forwards, the economy drops to 0.0l/100km. The engine is being turned over by momentum. At standstill, however, the meter changes from l/100km to l/hour - fuel is again being used to keep the engine running.
GTI MKVI Candy White | 5 door | DSG | ACC | 18" Detroits | Leather | Electric Seat | Sunroof | RNS510 | Dynaudio | Park Assist | RVC | MDI
Happy with the MT - even if 80% of my driving inner Sydney peak hour.
wouldn't swap for a DSG.
mk VI GTI, manual, reflex silver, basic
Always a hard choice by the feedback here and other forums.
Drove the s3 sportback today (dsg)
Awesome car. Great using paddles. Bloody expesive though 74K demo!! they are dreaming.
Guess I'll stick with DSG ..GTI.... now CW or TR damn....
2012 MY 13 Skoda Octavia VRS TDI liftback Brilliant Silver - Stock
Simple decision. Wife wanted an Auto. Wife gets what she wants . . . well sort of . . . DSG![]()
