Well that explains a lot.
driving in the wet is a bit of an art form - is paul morris any good at that?
re: the graphics on the 93 & 193 car (the grey part). You don't own a Salsa El Kaboing do you?
Went and grabbed a copy. Whole article is way too busy with the Aussie/Euro/Jap split and the points thing is way too complicated.
Not sure I really see the point of it TBH. But interesting to see how much people spend on mods!
Did Paul Morris damage a wheel rim in his laps in the Golf? A couple of times in the same position turn 11/12 he runs on the inside of the rumble strip and you can hear a loud thud.
Generally looked a very poor driving performance from a "Professional motor racer"
i was actually there .. that little s3 in the mag is mine... do you know how many goes they had at the STi to get that incredible number ???? 8 times to be exact because the tuner repeatedly refused to accept the numbers on the day and said their car was capable of quicker.
all the other cars got 3-4 shots at it and that was it.. i watched the STI through out the entire drag strip test.. they were only getting mid 4's and high 12s.
MY10 AUDI Q5 & MY10 S38P Forge CAI -- H&R F&R Sways -- Revo Stg 2+ -- Bilsteins PSS10 Coilovers -- AP Racing 6 Piston 365mm Big Brake Kit -- Pagid RS29 Race Pads -- Miltek TBE -- APR HPFP -- Recaro Sporster CS -- Enkei PF01
spot on macca..... my s3 are actually running pagid race brake pads and only work properly when up to temperature. They suck when they are dead cold.
my mediocre braking performance was hampered by the fact the brake bias on my S3 is heavily skewered to the front and running stock rears. I suspect I would have had better braking if i matched my rears.
the key factors that affect braking are
1. Calipers
2. Tyres
3. Pads (correc operating temperature)
4. Suspension (correct geometry, reduced brake dive)
5. Mass of vehicle
all of those factors affect braking.
should add... the dyno run on this particular dyno.... i was down.... 35kw at the wheels...
my car has reliably dynoed.... 215-220kw at two different dynos one hub one rolling.....
so i have no idea WHY my car was pulling such low numbers... but one thing that a lot of people are not aware of is semi slicks DONT make for great dyno testing... they just dont grip the rollers enough to get an accurate tractive reading...
oh yeh the car is capable of an even faster sprint time... if we could have dialed up more rpm on the rev counter.....
on street tyres with less grip i can get a 0-100 of 4.1 ... even moorly in the article acknowledges my car is capable of a much quicker 0-100 and 0-400 sprint time... just hampered by super stick semi slicks and a very sticky WSID
not me i was running bog standard factory camber... which is JACK all negative camber at the fronts.... craps me no end... my super stiff suspension and shock.. certainly didnt help my cause... in the wet.. just made my car too skittish due to complete lack of traction and very little suspension compliance.. in the mag it clearly says the more compliant suspensions probably performed a lot better that super stiffly sprung car..this affected my apex speed severely.. lack of grip and suspension compliance
its disappointing the second day was a wash out... i suspect the results would have been different if it was a dry track... some of the super cars like the STI and the EVO would probably have performed significantly better....i should also point out... EC suits high powered cars more
Warren Luff's comment to me regarding my car after the motorkhana and EC hot lap was .. my car is perfectly set up for the dry.. which was my original purpose and intention.... my car is set up aggressively to dial out the understeer... which means on a wet track it has a habit of stepping out and turning into snap over steer which luffy noted in his commentluffy had a hell of a time battling over steer on my car...
but his words to me were dont change the set up... as its set up perfectly for the dry
just needs more negative camber for outright grip!
