Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 77
Thread: MOTOR Hot Tuner Challenge
  1. #51
    Nov 2009
    Cook, ACT
    Guy,
    Given you have chosen the set up for cornering, would you offer comment about the relationship of the agressive wheel alignment camber, (neg 3 deg?), on braking and dragstrip performance?
    A lot of comment brake/tyre size but tyre contact patch is a big deal in these tests...
    I wonder how a streetable alignment might compare with a track setup? Any chance of a comparison between say neg 3 and neg 0.5 or 1?
    Is the transmission up to the loads that I suspect would increase with the whole tyre contacting the road?
    Were your direct competitors using such agressive cambers too?
  2. #52
    Nov 2006
    Georges Hall
    Quote Originally Posted by ethosguy View Post
    Guy,
    Can't speak for everyone,but most were running a fair bit of neg,which again detracts from braking performance.
    You have to compromise a bit in these events as you can't change set up at all,other than tyre pressures.
    So naturally you set your car up to its strengths.
    One thing that puzzles me,the Track Time was worth 20% of the final score.
    We got 20 for winning,the slowest car got 18.34...and it was 20 seconds a lap slower....
    Doesn't seem like just reward for winning the Track Time outright.
    Dyno results should be on % increase on stock,not overall.
    However,the guys at MOTOR do their best to make it as fair as possible but there'll always be some anomalies.
    One thing I think that needs addressing is to have the same driver for all the cars on the circuit.That way we know the driver is consistent in the result.
    Luffy is the man for the job here-he's awesomely fast and consistent in anything he drives.
    Bit hard to beat 6.0 Litre Supercharged Chevvies....
  3. #53
    Camber certainly does effect the straight line "power down" factor, and as Len mentioned - braking as well.
    For the track (and actually we normally drive this way on the street - but it kills the inner tyre tread) we run between 2.8 & 3 degrees negative.
    On our MKV which Motor managed a 13.8 1/4 mile in (3" camber & Hoosier Semi Slicks, we took it to the QLD drags, running street tyres & with 6 practice launches (and a camber or 1") ran a 12.9 second 1/4 mile.
    Mind you, practice launch after practice launch also helped - and they only did three total in the cars having never driven them before.
    That's why an Auto / DSG / PDK is also so much easier to jump in & drive.
  4. #54
    Talking bbout transmission loads, well.....our third car snapped a gearbox output shaft - clean in half on the dragstrip after a warm up run of 12.5 seconds. That's an issue of too much grip & too much HP, so yes, there is a breaking point.
    On my old Audi TT MK1 rally car, we managed to shear the rear prop shaft coupling on a bitumen "Launch" in a Dutton Rally. Made a mess, punched a hole in the fuel tank and all.
  5. #55
    Jul 2009
    Highlands NSW
    All hail the APR GTI
    I don't know what its like for a street drive but we can't help but be gobsmacked by the overall performance of the APR GTI. For a $64k car, and a few blades of grass off $20k cheaper than the APR Golf R, The modifications and overall package looks outstanding value for money, considering how close its results were to the R. What a fabulous result.
    Guy, I am sure that if you were asked before the event the categories you would most like to win, they would have been lap time and apex speeds (and I also have a sneaking suspicion that you would love to achieve a low or sub 4 second 0-100 time but that a DSG and another story away). Those two categories are the only categories that really matter when you are modifying a car a car to make it the quickest from A to B ---- and perhaps the only two that have any real meaning in this sort of comparison. Congratulations, you must be smiling from ear to ear with the results.
    You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
  6. #56
    Jun 2009
    Sydney NSW
    So what laptimes did the R and GTI pull at EC?
  7. #57
    Feb 2009
    Sydney, Australia
    The Golf R did 1:59.0 and the Golf GTI did 2:00.6 - both on a very wet track, and (I believe) both driven by a rather "laid back" Paul Morris.
  8. #58
    Erskineville, NSW
    Quote Originally Posted by coreying View Post
    bloodshot eyes or a headache?
  9. #59
    Feb 2009
    Sydney, Australia
    Well... I wasn't personally there, so I wouldn't quite go to that extent
    But I watched the video and it looked like someone on a "casual Sunday drive" in many places. You know - 1 hand on the wheel, the other hand on his lap... on a few occassions he found himself in completely the wrong gear coming out of a corner and had to change down a few when he realised it wasn't going to pull through unless he changed, etc. It's quite amazing that the Golf's were able to set the times they did! hehe
  10. #60
