Originally Posted by
elisiX
Hi All,
I've been trying to find the answer to this but have not had any luck.
In every picture i've seen of the MKVI GTI, i've noticed the 'screen' in the dash. In the MKV, I recall that you only received this with the Sat Nav option. Are all the MKVI's i've seen fitted with NAV or does it come with the screen regardless of whether NAV is fitted or not this time around?
The reason I ask is that if its simply a NAV module, then its bloody expensive. I tend to know my way around Sydney pretty well and would easily do without the NAV if it still came with the fitted screen/display. On the rare occasion that I do need to check a map - Google maps on my iPhone does the trick nicely.
If what I am assuming is correct above, would you guys think that it is possible to retro fit the NAV module at a later stage for the next owner of the car?
Thanks in advance.
Jay
