2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
Resident grumpy old fart
Thanks Corey_R but sadly Gummi Pflege didn't help for long in my case, a week at best and I haven't bothered to wax/polish the inside paint on my door frames as it just gets filthy again with Gummi Pflege! Seems all of our cars have this issue in different amounts!
Anyway, I am pleased to say that I installed the plastic irrigation tubing last night (could only get 4mm from my local Bunnings) and the creaking noise is gone. It's such a dramatic difference that it felt like driving a new car today. I am elated. Kaanage thanks again for directing me to the fix. I hope it lasts! So easy and only $4.
GTI, 5 dr DSG, Tornado Red
Cool. Looks like I'll be taking a trip to bunnings at the weekend then. Do you know how much is required in terms of meters?
2010 Candy White Golf GTI 5Dr. Manual, RNS-510, Bluetooth, Tints, GT-CX 18 Gloss Black Rims.
They only had 10m rolls of the 4mm diameter stuff so I bought it. $4. I used about half of it so ~5m. The guys in the US forums were using 6mm diameter tubing from Lowes stores. Anyway seems 4mm was enough, but if it compresses over time I will split the remaining 5m I have down one side with a Stanley knife and wrap it around the 4mm lengths I have already installed to bulk out the diameter a bit. It'll take you less than 10 minutes to install - just lift the inner flap of the felt along the upper door trims and push it in. Hope you are as successful jords.
Thanks for that. $4 for 10m isn't going to the bank. If 6mm is the preferred option then I might try and get some of that. Wonder if Masters do the 6mm? They're closer to me than Bunnings, so I'll them first. Looking forward to a creak free car.
I bought a roll of 6mm and the doors just wouldn't shut with it in the seals. I then presumed the US guys were referring to a Outer Diameter of 6mm, so bought some of the 4mm (Internal Diameter) irrigation tubing from bunnings which is actually 6mm (Outer Diameter) and it fits like a dream. Doors are a little harder to shut but the car is dead quiet now and doesn't rattle/clatter on bumpy roads or creak when braking.
Cheers Whitegti11, I didn't get round to going last weekend, which is a good thing, otherwise I would have bought 6mm.
So 4mm is the way to go. A job for this weekend.
