Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 68
Thread: MKVI GTI ECU Upgrade...Which is Best?
  1. #31
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by coreying View Post
    But now that these new VW's (and older cars depending on whether VW have 'retrospectively re-flashed with 1024 bit encryption') need to have the ECU physically removed to be flashed on a bench with the new APR equipment...
    Do they need to do it on a bench? I thought it more likely the first time APR see a new ECU code they needed to see it at HQ, but now the appropriate Equip is at the 15 distributors they not longer need pull it and send it back to HQ. My guess is they can still do it in situ. Could well be wrong though.
  2. #32
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by HereGoes View Post
    Bugger no Blufin any more...
    I just wanted a little bit of extra grunt to play with and i could justify $1,000 doing it but now you are talk almost double that for APR plus the risks with new car Warranty. It is fast becoming just not worth it really
    You have just bought a mk6 GTI and dont have 2k gfor the product it deserves. ? Weird...
    Im not saying buy APR, but if thats what you needed/chose as per what Fuzion said, your deciding factor is i dont have 2k....
  3. #33
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by logger View Post
    Guy_H would be the best person to answer, but looking at this thread that Tim supplied, it looks as though they literally have to remove the ECU from the car to plug it into the new APR flashing hardware.
  4. #34
    Jan 2008
    Shouldn't be long before APR have the ability to flash via the obd port going by their past performance either I would think.
  5. #35
    Jul 2009
    Highlands NSW
    Torque Logging
    APR still undetectable & security lockout (if you purchase it) still works!
    Is there any logging of torque maximums through the DSG that can be accessed by VW service.
    The apparent number of DSGs replaced under warranty mentioned on these forums gives me some cause for concern. Although it may not be attributable to increased torque, I am sure that the replacement debate with the dealer may be a little more difficult if 400 + NM have been logged through my TDIs DSG.
    You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
  6. #36
    Aug 2009
    Melbourne, Vic
    Yes I agree - He's the Man. Suspect its more a case of, they can chose to, but do not have to, remove the ECU to reflash it. Allows a customers to send their ECU to tuner without the car which would be convenient in some situations. They certainly did not have to remove the one in my MK6, but its not a GTI, its is older and its a different tune.
  7. #37
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Highlander View Post
    I'm not sure there is to be honest.
    Also, I don't think that the DSG issues are related to torque. Clutch failures sure, but not issues requiring the replacement of the DSG itself.
    APR have had Stage IV GTI's (I have no idea what stage iv even is, apart from it is able to launch a GTI from 0 to 100 in about 4 seconds and do over 300kph) with DSG gearboxes, and VW themselves equiped the Scirocco 24 hour cars with the DSG - so the 6sp wet-clutch DSG can take WAAAAAAAY more than 400NM
  8. #38
    Aug 2009
    Melbourne, Vic
    As far as I can see the DSG controller does not log torque. On the other hand a Fault Message may get logged if certain conditions are met. A properly built tune should not place the engine or gearbox in situations where faults are generated any more so than stock.
    If you were unlucky enough to have a power train issue (engine\gearbox) after an ECU tune, your first port of call should perhaps be to the tuner. They may then be in a situation to remove the tune, and clear any fault messages that may or may not be attributable to it prior to taking it to your dealer. For this reason the accessibility of your tuner down the track may be a factor when you decide who to go with.
  9. #39
    Point Cook, Vic
    Due to the new encryption its looking like all applicable ECUs need to be flashed on the bench. No doubt someone will crack it eventually. At this stage it looks like for GTI owners that ECU removal will be required from most tuners. Its no big deal really. It wasnt that long ago that chips were being soldered in.
    FOLLOW US ON FACEBOOK
  10. #40
    Dec 2009
    Toowong, QLD
    Quote Originally Posted by schoona View Post
    It is not about not having 2k to spend it is about cost/benefit. 1k for a little more power to play with that you will only get to use one in a while makes a lot more sense that 2k. That is a nice holiday! Priorities that is all.
    Life is a journey... enjoy the ride!
    Golf GTI MKVI aka Jane
