Results 1 to 10 of 24
Thread: softening the suspension
    In the absence of ACC, and the presence of the Sports Pack, I'm enjoying our new car alot but wondering whether it is a simple / sensible / cheap thing to consider getting the suspension softened a little as the hard suspension that comes with it is harder that we want.
    I've read a few similar comments on the suspension - some wanting it harder, some softer but other that choosing the ACC up front I've found little info on what it would take to fix it post purchase. Thanks
    2009 Golf 118 TSI DSG Sports Pack MDI
    Dec 2009
    I didn't order ACC with my GTI but I have gone with the 18" Detroit wheels. I am also interested in changing to some 19" wheels down the track once the car is actually in my hands.
    That being the case, I feel I too will need to look into suspension options. Something that I am thinking very seriously about is a Bilstien PSS10 coil-over system with 10 points of adjustment for damper.
    2019 BMW M3 CS
    Dec 2009
    I mean to also say that they are about $2000 USD before shipping.
    2019 BMW M3 CS
    Canberra
    People that are looking for a more comfortable ride often fit Koni FSD shocks and seem happy.
    Feb 2009
    Sydney, Australia
    @elisiX - the best thing you could do is just not put the 19" wheels on :p
    @kevin118 - what PSI are you running in your tyres? What tyres and wheels are they? If you're on 18's you could change to 17's. If the PSI is around 38 etc, you could change to 32. Lowering the PSI affects the handling of your car, but then, so does softening the suspension (unless going for high end options like suggested above, and then it's kinda evened out a bit).
    Dec 2009
    lol but Corey that would mean leaving the car stock
    I hadn't thought about the Koni FSD. I dont know how much they would soften the ride up, but they would provide a little tighter damper at speed.
    2019 BMW M3 CS
    Feb 2009
    Sydney, Australia
    Nothing wrong with that man. Is it really worth it to spend ~$2 to $4k on rims, then ~$1500 on tyres and then ~$3k on suspension (including shipping and fitment) to total $6,500 to $8,500 to reduce the profile of the tyre by 0.5" ?
    I could think of WAY better things to spend the $6,500 to $8,000 on!
    Dec 2009
    You make a good point - but the reason I would spend the money on suspension (coil-overs and not just FSD shocks for example) is to have the car riding quite low (looks) on those $2500-3000 of rims (inc. tyres). So yes to do this all up you would be in the $5k range or thereabouts. I guess in the end it's all about the look and maintaining some form of comfort. The advantage of making such a drastic change to the wheels and suspension is also better handling.
    I'll wait until the car arrives of course before making any decision or purchases, but 19" wheels is something i've always added to my car's (except the current Mazda) and the ride has never been an issue. With the TT, it was an expensive exercise to change wheels, tyres and suspension but it was worth it for the incredible look and stance it had as well as the riding on rails handling. It may not prove to be as much of a sound move on the GTI so I would certainly investigate further when the time comes.
    Hopefully by then quite a few of you guys have either modded your cars or left them stock and I can go for a ride on a GTG or two to determine the options available. The majority of my driving is by far the commute to work. For me that's from down SE Sydney to the City. That drive is basically main road or highway which is smooth. I rarely hit the back streets other than the odd evening or weekends. So I am not shy to a little firmer suspension. Also, more than likely the first mods I would do are the Stage I + intake and move up-to Stage II within a short period of time. The 18" Detroit's are not a bad wheel by any means.
    2019 BMW M3 CS
