Has anyone had any experience with the Pirelli Cinturato P7's? Thoughts on road noise and wet performance?
Skoda Octavia Mk3
(sold) Golf Mark 6 Comfortline 118
(sold) Golf Mark5 Comfortline Manual 2.0 FSI
http://www.ecstuning.com :: Phone: 1.800.924.5172 - Hours:Mon. - Fri. 8:00AM - 11:00PM Sat. 10:00AM - 7:00PM EST :: Email: sales@ecstuning.com & customerservice@ecstuning.com :: Facebook :: YouTube :: Live Chat :: Instagram
Have tried searching for this in various spots (and tagged it on the end of another thread), but am curious on other people's end results on Australian mk6 GTIs.
I am wanting to avoid any rub issues on a lowered GTI - 20/25mm VWR springs - so have a choice between:
1) 18 x 8 ET48 is -3mm/+9mm (internal/external) over stock Detroits
OR
2) Save $50 and buy 18 x 7.5 ET50 with +1mm/+1mm change over stock ie negligible.
So do I play it 100% and go with near enough to the same size stock wheel, or am I fine with the slightly wider wheel which I assume will give the appearance of slightly filling out the guards a little more (as much as the eye can detect 9mm??).
Staying on 225/40 rubber as well.
my 18x8 +50 wheels with 225 40 18 tyres have not caused any detectable rubbing issues on normal streets. on tracks, i notice the plastic liners still get shaved tiny little bit.
my second set of wheels 18x8 +45 with same sized tyres, did rub when i hit a dip during slow downhill cornering. i did the 'fender screw mod' and the rubbing issue was removed on normal street driving. however on track, the inner plastic liners still get shaved a bit.
the rubbing issue is at the front fenders, the rear ones is an easy fix with more -ve camber, say 1.5 degrees.
different tyres with same size do have variations on the sidewall thickness though, some more protuded some less.
my mk6 is lowered on bilstein pss10 with 1 thumb gap at the front.
18x8 +48 should be fine with 225 40 18, look better than 7.5 +50 if lowered
MINI Cooper S Clubman - FWD
Thanks for that..!
The car is probably not going to see track work any time soon (although I wouldnt mind at some point), but will enjoy some country drives where downhill dips and the like are common place.
I'm aware of the fender screw mod, sounds like I will need to give this a crack once lowered. The drop I'm going to get sounds like it will be a tad less than yours so I don't think I'll have any issues, but I supposed I can judge this once it has been done - plus I'll see what 18 x 7.5 ET51 looks like at that point as well.
I know this is a fairly conservative move compared to what other people are running, but I am trying to avoid having to fiddle with things to much.
Thanks, you and me both on the colour choices. I'm a little sick of black, white and a few different shades of grey.
