Page 51 of 83 FirstFirst ... 41495051525361 ... LastLast
Results 501 to 510 of 821
Thread: MK6 Wheel / Rim / Tyre Thread
  1. #501
    Jul 2009
    Has anyone had any experience with the Pirelli Cinturato P7's? Thoughts on road noise and wet performance?
    Skoda Octavia Mk3
    (sold) Golf Mark 6 Comfortline 118
    (sold) Golf Mark5 Comfortline Manual 2.0 FSI
  2. #502
    18" Style 0.05 Polished Wheels - Staggered
    18x8.5 et42 / 18x9.5 et40, 5x112 73.1 CB
    http://www.ecstuning.com
    :: Phone: 1.800.924.5172 - Hours:Mon. - Fri. 8:00AM - 11:00PM Sat. 10:00AM - 7:00PM EST :: Email: sales@ecstuning.com & customerservice@ecstuning.com :: Facebook :: YouTube :: Live Chat :: Instagram
  3. #503
    Jul 2007
    Canberra
    Quote Originally Posted by ECS tuning View Post
    Wouldn't the rears scrape like a mofo?
    Forever blowing bubbles.
  4. #504
    Quote Originally Posted by nat225 View Post
    i think each person's perception about rubbing is not consistent.
    For 18x8 +45 or more aggressive the rubbing occurs in a lowered car, when cornering hard or driving fast on deep dip, on track / twisties.
    Won't happen while driving normally at legal limits on normal streets. If it does, then your wheels / tyres are way too aggressive OR you drive too fast on public roads!
    Have tried searching for this in various spots (and tagged it on the end of another thread), but am curious on other people's end results on Australian mk6 GTIs.
    I am wanting to avoid any rub issues on a lowered GTI - 20/25mm VWR springs - so have a choice between:
    1) 18 x 8 ET48 is -3mm/+9mm (internal/external) over stock Detroits
    OR
    2) Save $50 and buy 18 x 7.5 ET50 with +1mm/+1mm change over stock ie negligible.
    So do I play it 100% and go with near enough to the same size stock wheel, or am I fine with the slightly wider wheel which I assume will give the appearance of slightly filling out the guards a little more (as much as the eye can detect 9mm??).
    Staying on 225/40 rubber as well.
  5. #505
    Dec 2006
    Kilsyth, VIC
    Finally got some new shots of my Oettinger RZ wheels on after a tub:
    18"x8"
    PCD 5x112
    ET45 (approx)
  6. #506
    Jan 2011
    Brisbane - QLD
    my 18x8 +50 wheels with 225 40 18 tyres have not caused any detectable rubbing issues on normal streets. on tracks, i notice the plastic liners still get shaved tiny little bit.
    my second set of wheels 18x8 +45 with same sized tyres, did rub when i hit a dip during slow downhill cornering. i did the 'fender screw mod' and the rubbing issue was removed on normal street driving. however on track, the inner plastic liners still get shaved a bit.
    the rubbing issue is at the front fenders, the rear ones is an easy fix with more -ve camber, say 1.5 degrees.
    different tyres with same size do have variations on the sidewall thickness though, some more protuded some less.
    my mk6 is lowered on bilstein pss10 with 1 thumb gap at the front.
    18x8 +48 should be fine with 225 40 18, look better than 7.5 +50 if lowered
    OR
    MINI Cooper S Clubman - FWD
  7. #507
    Thanks for that..!
    The car is probably not going to see track work any time soon (although I wouldnt mind at some point), but will enjoy some country drives where downhill dips and the like are common place.
    I'm aware of the fender screw mod, sounds like I will need to give this a crack once lowered. The drop I'm going to get sounds like it will be a tad less than yours so I don't think I'll have any issues, but I supposed I can judge this once it has been done - plus I'll see what 18 x 7.5 ET51 looks like at that point as well.
    I know this is a fairly conservative move compared to what other people are running, but I am trying to avoid having to fiddle with things to much.
  8. #508
    Quote Originally Posted by The_Hawk View Post
    These are sweet.. the charcoal/graphite suits the blue. Wish VW expanded their GTI color pallet here..
  9. #509
    Dec 2006
    Kilsyth, VIC
    Thanks, you and me both on the colour choices. I'm a little sick of black, white and a few different shades of grey.
  10. #510
    I know there is a lame Fifty Shades of Grey line in there somewhere.
    I counted 34 choices so far on the new GTI in Germany.. sigh..
