Don't start with the Nitrogen argument in this thread please. There are threads in the "General forum" on that topic. If you want advise or more information, search in there. Cheers
Nitrogen is a waste of time and money as most cars don't have rims with double valves whichbleed away excess oxygen and only keep the nitrogen. The only benefits r lightening of ur wallet
2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
Hi everyone!
I've just got my MK6GTI 2 months ago and was looking at putting on some BBS CK 19" rims on the car. Was wondering if anyone has tried them out? If so.... was wondering if the springs needed changing or is it ok with stock standard and if there were any rubbing issues.
Thank you!
Hi All.
S3 wheels are fitted!
Don't look anywhere as good as they did on the GTI... Offset is wrong, they look too far into the arches.
I was previously correctly advised that I wouldn't have any issues with caliper clearance with these wheels. No issues there.
However I seem to have a problem with slight rubbing on the inside of the front wheels when they are on a tight lock (approx three quarters lock to full lock). Seems to be against the struts / shocks, as I can't get my finger between the back of the tyre and the shock strut. I have DCC if this makes any odds.
At low speed this doesn't seem to be an issue, but I'm wondering if I will have futher issues at speed.
Any thoughts?
I picked up my GTD just over a week ago. Today I checked the cold pressures to find 38psi in the fronts but 43psi in the rears. Seems a bit excessive for rears, certainly well above the suggested pressures on the tyre placard. I also noted as I let them down to match the fronts the vented air was very sweet smelling.
MY20 Golf 7.5 R - Blue
My whole life I've been a michellin and Bridgestone Fan.
dont want anything made by Dunlop, and didnt really like the Conti CS2.
BUT, the GTI has me hating the re050's
great tyre.. until you go to rotate them. Seems that they suffer a bit of heel & Toe wear pattern on the rear axle of teh golf. The noise when rotated to the front is horrendous. So much so I thought I had buckled my rims. Called up my trusty tyre and alignment dude, and once he asked me what car it was.. he told me it wasnt worth booking in for a balance.. knew the problem and described it to a tee...
sounds like its a balance issue, but there is NO vibration from teh steering wheel. sounds like a wheel bearing issue. Effects lower profile tyres, and some treads are more subject to it than others
Running the hand over teh tyre you definitely feel a wear pattern that isnt flat.. and spirited driving has seen chinks of teh tread ripped off.
Definitely not impressed.
So.. for you guys out there.. rotate every 5,000Km or dont do it at all...
It is so loud and annoying that I was contemplating buying new tyres...but, now.. cant wait for the new car to arrive as I wont be shelling out $1K in tyres for the next owner to enjoy...
More opportunites have been lost from indecision, rather than wrong decision....
I've just done 25,000 in my GTI with the RE-050s and they were starting to get a rhythmic whir like a bearing had gone. Have had a wheel alignment done (it was out a bit) and that seems to have eased the noise a bit. I do a lot of highway driving so don't know if that makes it worse.
I had exactly this problem with the Bridgestones on my previous ride - Honda Euro. It sounded like I had out-of-round off-road tyres when driving on smooth bitumen. There was no vibration or shudder in the steering, but the noise made people turn and look.
I ended up replacing them for Pirellis with still a good 15,000 left on the tyres. The difference in noise was stunning. The tyre shop suggested it would prevent the whir if I got an alignment every 15,000.... which is less than six months for me.
Steve
__________________________________________________ _________________
GOLF GTI MkVI DSG
Dunlops r notorious for road noise, running the sport maxx gt and can confirm they r loud. Will look at yoko s drive next
