Hey team,
Hoping some of you experts might be able to help me out as with my limited scan resources google isn't really helping me at all.
I have a 2009 mk6 golf tsi 1.4 90kw, I've been having issues with it going into transmission limp mode semi intermittently, I have just recieved the vehicle back after returning it to the useless used dealership and it was fine for 200km but has now re entered limp mode. I don't have access to vagcom or whatever to get a real scan so I went to supercheap auto for a basic scan and got a whole list of fault codes.
As I understand a lot of these codes are basically useless generic codes but I wanted to post them up here in hopes that the fact that all of these codes have appeared is a sign of something specific.
Central Electronics ce 3.3
0D44 Central locking system power supply terminal 30 : Open circuit
Steeing collumn switch module 3.0
0240 Relay, Terminal 15, Engine compartment : Electrical fault in circuit
0373 Ignition lock terminal S : Electrical fault in circuit
0375 Ignition lock terminal 50 : Electrical fault in circuit
0374 Ignition lock terminal X : Electrical fault in circuit
06D0 Ignition lock terminal P : Electrical fault in circuit
Instrument cluster 4.0
U1111000 Function restriction due to absense of message
Gateway 3.0
0523 Transmission control unit : No signal
0519 Audio CAN data bus : No signal
Does this ring any bells for anyone? Has anyone had transmission limp issues before and solved them?
I'm really at a loss for where to go next, and I'm not particularly comfortable with wiring and testing these issues just to make it worse haha
Any advice would be much appreciated.
Thanks in advance
Edit: Just remembered I should probably add that I have had no engine lights at all.
Bump bump
