Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 140
Thread: MK6 Replacement Brake Pad Thread
  1. #111
    Dec 2008
    Sydney/Canberra
    Rears on Australian-delivered non-Rs and non-GTIs are all the same size.
  2. #112
    Sep 2009
    Redcliffe, Qld
    Lot of great info on here so I'll add some long term reviews:
    Stocks lasted ~60000ks after which I put on DBA T3 4000s & Remsas all round. Definite upgrade in stopping power.
    15months later the front remsas were gone (one failed from too much happy lapping) so I switched these to EBC Reds. Wasn't expecting much based on the bad/ricer rep, but they have been pretty good, slightly stronger stopping than the remsas + less dust.
    Overall the rear Remsas have held on well, and would definitely recommend these for any street use / OEM replacement.
    I now have a shudder that only shows up under heated/heavy use and all the pads are getting close to 2mm. No complaints as these rotors have lasted ~80,000ks including 25ish lap sessions.
    Bought replacements today DBA T3 rotors all round again & based on a conversation with GSL/Brakes Direct I'm going Forza FP3 pads at the front with remsas again at the back.
    MkVI Golf GTI
  3. #113
    Jan 2011
    Brisbane - QLD
    Quote Originally Posted by DarkShines View Post
    my experience with Forza FP3 and DBA T3 combo has been all good. they are quiet (for performance pads) for daily and perform really well at lakeside, qr and morgan park (with fresh brake fluid).
    MINI Cooper S Clubman - FWD
  4. #114
    Sep 2016
    Hey guys any idea how much it would cost to replace all pads with OEM/aftermarket (including labour) on Golf R MK6? My car has done just under 60k and thinking of changing pads soonish. VW had a September deal that was about $550 but missed out, while my local VW dealer is a joke when it comes to customer service.
  5. #115
    Erskineville, NSW
    Quote Originally Posted by Arkanoid007 View Post
    Why are you "thinking about it"? They either need doing or don't.
    just pads or pads & rotors? It's very rare to get away with just pads if factory VW rotors are fitted as they appear to be made from butter.
    Labour is about 1.5-2 hours per end.
    pads are about $100 per end but can start as low as $60 and go way above $200.
    front rotors are anywhere from $90 each to $220 each
    rear rotors are anywhere from $70 each to $160
  6. #116
    Sep 2016
    I check my pads and still seem in ok condition. The car doesn't shudder when breaking but I can hear squeaking at times when applying low brake force at low speeds. Either way it sounds like 500-600 for all pads and around 1000-1200 with new rotors. Thanks.
  7. #117
    Oct 2016
    My rotors are lipped the sh*thouse and pads are extremely low. Car is currently at exoticars getting the brakes done with a major service. I went for DBA T2 all round, Remsa pads and HEL braided lines. You lot better be right about these Remsa pads! My expectations are high!!
    | 2016 VW Golf R 7 | DSG | Pure White | Leather | Sunroof | Driver Assist | JB4 |
    | 2003 VW Golf SE | Auto | Silver | Sunroof |
    | 2010 VW Golf R 6 | Manual | Leather | ACC | 19s | Black Pack | GIAC Stage 2+ |
  8. #118
    Oct 2016
    I ran EBC Red stuff pads on my 400kw Evo 8 and I had the same problem - although the rotors felt warped, it seemed like they have "high spots" on the rotors and only happened after a very spirited drive (the fluid actually cooked and had to be replaced)
  9. #119
    Sep 2010
    Southern Highlands NSW
    Hi all, im due for my 3rd set of pads and rotors for my mk6 gti . Ive had OEM then tried the Remsa but was a little disappointed with the amount of brake dust these produced. Ive decided on T3s up front and T2s on the rear but cant decide on which pad to run. Looking at Akebono or Stoptech atm. Is there a place locally that stock these or is OS my only option? Any input is welcome.... the car is not a track warrior but i do like my wheels alot so i would like to keep the brake dust to a minimum
    Polo GTI
    T-Roc R
    Tiguan R
  10. #120
    Dec 2008
    Sydney/Canberra
    ATE Ceramic, if you want to keep the dust and noise down.
    They do stop a bit better than OEM, too.
