Page 11 of 14 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 140
Thread: MK6 Replacement Brake Pad Thread
  1. #101
    Apr 2013
    The Gap, Queensland
    I did t3 front and t2 rear and Remsa pads all round
  2. #102
    Apr 2016
    Qld
    Quote Originally Posted by prh1973 View Post
    Roger may need to copy that
    Volkswagen Mk7 Golf GTI 40Y Clubsport
    Tuned by Tarmac Engineering / Spectune
    @ Bayside Performance Services Cleveland Brisbane
  3. #103
    Apr 2013
    The Gap, Queensland
    Quote Originally Posted by Mdanrex View Post
  4. #104
    May 2012
    Kallangur, QLD
    Some great information in this thread and I'm almost tempted to replace my own pads however just had the 75k service done on my MKVI GTI and they told me I need the front pads done and also the callipers. When questioned they said they always do both. Seemed strange to me but wondered if anyone else has found this or are they just upselling? They also advised has to be done in the next 1000-2000km and there is 5mm thickness.
  5. #105
    Apr 2013
    The Gap, Queensland
    If you are replacing your pad the discs will need machining but is not really cost effective and also the discs may end up too thin after machining. I only got 50k out of mine with some track work so you have done well to get 75k. The stock discs are soft so I don't think they are upselling. I would not replace the discs with OEM nor pads. Feel you disc now to see how much lip is on the outside edge of the face. This will give you an indication on how much thinner they now are.
  6. #106
    I think you mean disks not calipers
    Quite common to replace the disks at those sort of km's, and the pads are quite aggressive and the disks are quite soft - so they wear out quickly. Grab new disks (either OEM or aftermarket like DBA) and then get some less dusty pads like the Remsa pads i am using. Ive had these pads on my Golf R and now on my GTI and they are great.
  7. #107
    Apr 2015
    Hills Area, Sydney, NSW
    I have an ECS front and rear brake upgrade on my golf R mk6, highly recommended you investigate this as an option.
  8. #108
    Erskineville, NSW
    Quote Originally Posted by Sprocket View Post
    It would be pads & disc rotors, not pads & calipers. Pads & rotors are normal on a Euro.
    The OEM pads are 14mm thick when new. With 9mm of wear in 75,000km and a minimum pad thickness of 2mm (VW's parameters in the workshop manual), you have about 25,000km of pad life remaining. Even being conservative, you have at least 10,000km to work out what you need to do and get some alternative prices.
    I don't think the dealership is trying to rip you. By neccessity they have to be conservative in their estimates as they don't want you going metal-on-metal between services.
  9. #109
    May 2012
    Kallangur, QLD
    Thanks that gives me some comfort and I'll do front and rear at same time probably cheaper than dealer quote ($600) for just front. Looks like Brakes Direct way to go and they are local. Will keep researching now that I have time.
  10. #110
    Any feedback on QFM Euro pads?
    Also noticed that the 118TSI seems to have three possible rear pad sizes. Confusement.
