Page 109 of 118 FirstFirst ... 95999107108109110111 ... LastLast
Results 1,081 to 1,090 of 1178
Thread: Mk6 LED Taillights
  1. #1081
    Nov 2009
    Quote Originally Posted by Rawcpoppa View Post
    Ok. I wonder why VW puts the byte 18 value back to 00 to hide the true value in some cars.
    Should I discount using values that are presets for other vehicles? e.g. 04 for Golf GTI or can codes be shared between vehicles models?
    The value isn't put back to 00 to hide anything. But it may well be that modifying some bit, or combination of bits, has other effects (such as internal state changes for instance) that means that reverting the configuration doesn't in of itself restore the original behaviour. We don't have the specifications or a build guide to work against.
    VCDS should know that the module is Jetta-specific, unless it's not Jetta-specific, in which case the answer is... I don't know. I would have thought the modules (or software versions at least) would not be shared between vehicle types, but who knows. Again, Ross-tech is your best bet. You can try any of the configurations that you think may yield the desired results. As I said before, I don't think it's likely to do any damage at all, but I can't promise anything.
  2. #1082
    Trinidad and Tobago
    I tried presets for other models including the GTI. You were right. They didn't do any damage. They did lead to wonky behaviour though. Reverse lights on in park. Dim park lights etc.
    Thanks for the help so far.
  3. #1083
    Leaking Tail Light.
    Can't see any gap, but water is in there. Should I drill a tiny hole on the inside (black part) of the lens assembly? It would not affect the lens itself, but not sure if it will cause more issues than it solves....
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  4. #1084
    Nov 2009
    Quote Originally Posted by sVWatt View Post
    Leaking Tail Light.
    You went with aftermarket (non OEM) tails, didn't you? Hate to say it, but this sort of thing is much more likely to happen with the eBay aftermarket stuff.
    If you drill a hole, you'll just allow more moisture to get in and cloud up the lights on an ongoing basis. They really should be completely airtight. Your best bet is to let the lights sit in the sun (or apply gentle heat) and the moisture will hopefully evaporate. No guarantee this won't happen again of course.
  5. #1085
    Quote Originally Posted by AdamD View Post
    YUP
    Ebayer said they will send another set if I send mine, but don't want to swap back to original tails and back again to new led's, so hoping he will go with a deposit from me to send new set and refund once he receives oldies back...
    Few...all good. He will send out a replacement set and hold a deposit till the wet one gets back.
  6. #1086
    May 2010
    WA
    Leaking Tail Light.
    The same thing happened to my tails after using a pressure sprayer a bit too enthusiastically to clean the car- and they are original parts. I took the lights off, poured out what I could and then used a hair-drier to completely dry them out. took about 15 min. Couldn't find any cracks or gaps and have been fine since...
    Golf VI GTI MY13 Candy white/ DSG/ Detroits/ tint/ reverse camera/ parking sensors
    2016 Skoda Octavia 162TSI RS Wagon (Silver/DSG/Tech pack/ Black pack)
  7. #1087
    Quote Originally Posted by darkfriend View Post
    Thanks good to know. If the replacement set does the same thing - Ill try your solution. I also bought some flexible clear sealer from Bunnings, so might apply that around the assembly before installing . . .
  8. #1088
    So what's the current go, then? Go OEM (~$700) or something like the VACAR copy (~$350?)?
    How did you end up going with this?
  9. #1089
    Nov 2009
    Quote Originally Posted by moda View Post
    OEM all the way, IMO.
  10. #1090
    Replacement lense still enroute.
    Will let you know once it arrives and I swap it over
