Page 108 of 118 FirstFirst ... 85898106107108109110 ... LastLast
Results 1,071 to 1,080 of 1178
Thread: Mk6 LED Taillights
  1. #1071
    Recon that's a fair price GTD Dubber with fitting and coding. Did you go for OEM tails or aftermarket ones?
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  2. #1072
    Apr 2012
    Gosford, NSW
    I got the OEM ones through Ozram's contact in Germany.
    MkVI GTD fitted with Bluetooth & MDI, CSG, DSG, Xenons, RNS510 with Dynaudio, ACC, Weathershields, Mudflaps, Sunroof, LED Tails, LED Indicators, LED Foglights, Interior LEDs, Tinted, RVC and Towbar - Gosford.
  3. #1073
    Central VIC
    ^ Same here, very happy with them 12mths on
  4. #1074
    Nov 2010
    Quote Originally Posted by GTD Dubber View Post
    me too! its been close to a year.
  5. #1075
    Sep 2011
    New South Wales
    Just so you guys are aware there are some solutions from JOM available:
    JOM - Main page » Catalogue » Vehicle Types » Volkswagen » GOLF VI » Lighting
  6. #1076
    Trinidad and Tobago
    I have a mk6 Jetta and recently installed OEM LED tails. I know they aren't the same car but the mk6 Jetta and Golf share alot of parts underneath. This is my CECM with fault code after installation:
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
    Component: BCM PQ35 M 021 0064
    Revision: BC021001
    Coding: 08000A3F882DE1C040080080040081E447200088508089605C 8020000040
    Shop #: WSC 00066 123 12345
    VCID: 3E5DE7A5A9CECAEEBC5
    Subsystem 1 - Part No: 1K8 951 171
    Component: DWA-Sensor 00 001 0104
    Coding: 000000
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Coding: 000000
    2 Faults Found:
    00984 - Left Tail Light (M4)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 214
    Mileage: 35134 km
    Time Indication: 0
    Date: 2017.14.08
    Time: 00:04:01
    Freeze Frame:
    Term 15 On
    Voltage: 12.15 V
    ON
    ON
    OFF
    OFF
    OFF
    00985 - Right Tail Light (M2)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 214
    Mileage: 35134 km
    Time Indication: 0
    Date: 2017.14.08
    Time: 00:04:01
    Freeze Frame:
    Term 15 On
    Voltage: 12.15 V
    ON
    ON
    OFF
    OFF
    OFF
    Do you guys have similar models of CECM? I'm thinking of trying the byte 18 set to 15. Do you think this might be bad?
    These are the options I see in VCDS:
  7. #1077
    Nov 2009
    Your control module is completely different to that in the Golf, so all bets are off. I'd be contacting Ross-tech for advice if I were you.
  8. #1078
    Trinidad and Tobago
    Quote Originally Posted by AdamD View Post
    Ok I will do that but I am itching to try various codes in byte 18.
    If I know that my default byte 18 value is 8C can I try other values and just go back to 8C if the other values cause trouble? Can any values in byte 18 damage the cecm preventing me from going back to 8C?
  9. #1079
    Nov 2009
    Quote Originally Posted by Rawcpoppa View Post
    Damage is pretty unlikely; the risk is low, but there is always some risk. I'm not about to tell you that you should do it, but if it was me I would probably try a few of the more likely values myself.
    Changes in coding to byte 18 that can't be easily reverted have been documented, but the only case I know of with that is when the original coding was 00, and in order to go back to a factory coding there was a need to code to another particular value first, and then revert to 00. And I don't know how much of all that was down to actual understanding of the system, and how much was down to guesswork and observation. (I know that one of the coding boxes that one of the online retailers sold along with LED tail lights did this.)
  10. #1080
    Trinidad and Tobago
    Ok. I wonder why VW puts the byte 18 value back to 00 to hide the true value in some cars.
    Should I discount using values that are presets for other vehicles? e.g. 04 for Golf GTI or can codes be shared between vehicles models?
