Page 100 of 118 FirstFirst ... 50909899100101102110 ... LastLast
Results 991 to 1,000 of 1178
Thread: Mk6 LED Taillights
  1. #991
    Camberwell, Vic
    Chaps
    A question relating to putting standard lights BACK on the car after removing LED's - is the standard hex for Byte 18 00 and thus standard binary 00000000?
    Only I need to turn my MY10 with halogens back to standard and of course stupidly did not record what the original was? I assume 00 if the default though?
    Thanks
    2010 R36 (MY10.5), Biscay Blue, RNS510, MDI, Electric tailgate, sunroof, Superchips remap - SOLD
    2016 Octavia VRS wagon, moon white, Tech Pack, 18" black pack, electric boot, panoramic sunroof, Bluefin
  2. #992
    Nov 2009
    Quote Originally Posted by kryten2001 View Post
    Figured it out, son of a B****!!!
    The wiring adapters provided were wired up BACKWARDS!..
    Certainly sounded like a hardware/wiring issue. Good to hear you got it fixed up.
  3. #993
    Nov 2009
    Quote Originally Posted by slipshot View Post
    Most I've seen are 00 before being coded.
  4. #994
    Dec 2008
    Perth, WA
    Quote Originally Posted by AdamD View Post
    Mine were coded 02. I made a special point to check this just in case I had to ever set them back.
  5. #995
    Apr 2009
    Chaps
    Thanks
    When I did mine I went in and selected C0 Lighting : Reset from the drop down box. I left it at that and all the lights worked fine. In hindsight I think I should have reset and then gone back in and recoded to option 02 like kryten2001 said. (see below)
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
  6. #996
    Camberwell, Vic
    Just to confirm.
    I reset it to 00 (Co Lighting reset) and it worked fine - and then I checked the rear lights, and the two inner ones were far brighter than the two outer ones (or vice versa) but an obvious difference.
    I then reset it to 02 and all worked fine and back to normal. Thus I would suggest for those resetting there's that 02 should be the first point of call...
  7. #997
    brisbane
    with out having to read this whole thread,
    what is the cost shipped to brisbane?
    MY11 GOLF GTI MK6 | CSG| DSG
    APR Stage 1
  8. #998
    Apr 2009
    Quote Originally Posted by vwgtimk6 View Post
    No.... No clues!!!
    You must read the whole thread to qualify for that information.
  9. #999
    Jun 2009
    Perth, WA
    Blacked out rear light clusters
    Are these legal in Australia and if so where can I get them in Perth and are they easy to fit?
    2010 | Mk 6 | Golf GTI | DSG | black | 18" Detroit's | MDI
  10. #1000
    Nov 2009
    Just to confirm.
    I would suggest you take note of what your original coding was when you change it (as is advised by Ross-tech whenever making a coding change), and restore to that!
