Page 78 of 118 FirstFirst ... 2868767778798088 ... LastLast
Results 771 to 780 of 1178
Thread: Mk6 LED Taillights
  1. #771
    Oct 2011
    Donvale, Victoria
    Thanks Adam.
    Had the coding performed and it would appear the Central Electrics Module has been updated.... For my June '11 build MY12 GTI, it is now 0651 ie. BCM PQ35 M 110 0651.
    The setting was changed from 2 to 4 (15 was not a selectable) and all working as expected w/o the error. A big thanks to Peter from a local VW shop for making the update.
  2. #772
    Aug 2011
    Melbourne, Victoria
    Quote Originally Posted by Zircon View Post
    Thanks Adam.
    Zircon,
    If you have a cable, can you post the complete coding? Thank ye!
  3. #773
    Oct 2011
    Donvale, Victoria
    Quote Originally Posted by mythik View Post
    Zircon,
    Hi, the workshop did the change for me, however I took some pics as attached. Hope this helps .
  4. #774
    Nov 2009
    Thanks Zircon! I've updated the coding post accordingly.
  5. #775
    Jan 2012
    Melbourne, Victoria
    How easy is it to install R LED tail lights?
    I have a MK6 Gti, really wanting the LED tail lights for it, can i fit them myself? do they need an adaptor with the current setup? also where is the best place to get them from? HELP!
    Woops meant tail lights
  6. #776
    Aug 2011
    Melbourne, Victoria
    You work for Essendon Volkswagen; have spare parts look up one of your floor model Golf R VIN's in ETKA and order the tail lights for you.
  7. #777
    Nov 2009
    Have a read through this thread, starting with this post.
    Also, please check the following thread (containing info on many topics commonly discussed in the forum) before creating a new thread:
    The Official MK6 Forum Important Threads & Posts Index **LOOK HERE FIRST**
  8. #778
    Aug 2011
    Melbourne, Victoria
    Can't quite see the complete coding. If you are coming to Dubstitute I'll be taking along my VCDS laptop and cable so I'll get it there.
  9. #779
    Dec 2008
    Northern Suburbs
    Byte 18 has a drop box which you change, very easy, never use anyone else's long coding every car is different
  10. #780
    Aug 2011
    Melbourne, Victoria
    Quote Originally Posted by PeDiES View Post
    That was what I was going to look at. I'm aware that differences in module versions / batches results in sometimes slightly different coding.
