Use of VCDS in of itself isn't going to affect your warranty - unless of course you use it in such a way that causes damage to the vehicle. There's no warranty provided by Ross-tech or any operator against potential damage there, so caveat emptor. Of course if you use it in the manner prescribed by others in this thread, you should be absolutely fine.
The VCDS change is made to tell the central electrics module that LEDs are fitted, and to expect them to draw less current than incandescent bulbs (and therefore not throw errors when they do). In most circumstances you shouldn't need to clear any fault codes - they should clear by themselves after you've made the appropriate change (mine did).
I have a MY2012 GTI and enquired with my dealer whether I could install R LED tail lights. They advised I had to not only buy the lights approx $1200 but also because of the different wiring a control box also costing about $850.
How are people on this thread able to install with just the lights and wiring adapters?
There's currently a group buy on www.golfmk6.com for R Tails if anyone is interested .
Be quick, spots are limited.
Formally known as mk6tsi
Not sure where on that forums the group buy is, but keep in mind that you need to get specific lights, and not just whatever the Americans are buying...
Found the group-buy thread here: **3rd Official OEM Golf R LED Tail GROUP BUY** - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
What differences are there between USA versions and Aus, is it a RHD/LHD thing, or just the fact that we choose the ones that come with a fog light (since the thread says it's ok for Australian buyers).
I'll let someone review the thread and reply. The hardest decision is working out what colour tails would best suit by Shark Blue Golf...
The US has two reverse lights and no rear fog, they also have a different light switch to us.
Australian spec is reverse light on L/H (near / passenger) side and rear fog on the R/H (off / driver's ) side. Anything other than the Australian spec and you are running illegal lights on your car as they don't conform to the Australian Design Rule standard.
Although the genuine part numbers of the lights have changed a few times, I'm yet to see any physical difference between the lights I've had for 18 months or more and the current ones.
HTH
GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
Hi All,
This might not be the best thread to start my first post but I just want to thank ozram for his tremendous help in sourcing these RTails from Germany quickly. I placed and paid for the order on 21/10/11 and package arrived on monday 7/11/11. Not bad I'd say. Everything was smooth n easy with installation n coding with vcds was spot on first time!
Again, thank you for the help Ozram and also everyone on this forum for all the knowledge base which couldnt be found elsewhere.
Now if anyone ever needs my assistance in doing this project please feel free to let me know, I'm more than happy to contribute my share.
Have a great weekend,
Ernest
MY12 MKVI GTI | Deep Black Pearl | 5 Door | DSG | Bi-xenons - LED DRL | Sunroof | 18" Detroits | RNS510 | RVC | R Tails |
