Page 68 of 118 FirstFirst ... 1858666768697078 ... LastLast
Results 671 to 680 of 1178
Thread: Mk6 LED Taillights
  1. #671
    Oct 2009
    Quote Originally Posted by backdoc View Post
    Interesting discovery, after checking all the connections (which were all good) - with the DRLs set to on in the lights section of the menu, led tail light cluster is on. Turn off the DRLs and the tail lights instantly turn off also.
    I guess this is a feature. DRLs front and rear?
    Bump. Can anyone with the Xenons & LED DRLs that have also fitted the LED R-tails mind checking if they are finding the same thing with the rears working in tandem with the DRLs and only switched off through the MFD & unchecking the Daytime Running Lights box?
    Thanks
    MY10 Skoda Octavia RS Wagon TSI Candy White DSG Leather Sunroof MDI Bluetooth Tow Tint
    MY11.5 Mk6 Golf GTI 5dr Candy White DSG Detroits MDI Bluetooth Bi-Xenons RVC Tint R-Tails - SOLD
    MK5 R32 3dr Black DSG - Loved it
    MY14 CLA45 AMG
  2. #672
    Thanks
    Not sure if this is going to help, my GTI came fitted with DRL's and R tails from the dealer (Adidas version came like this) these are not aftermarket. The DRLs when turned on in the MFD and the light switch set to 'A' the tails are NOT on. If you switch to 'parkers' (one after 'A') the DRL's dim and the tails turn on.
    MK6 Golf GTI ///Adidas | 9N Polo GTI | 96 Seat Ibiza 8v GTI
    Quote of the day, from my wife.... "Stop washing your car... it's going to rain anyway"
  3. #673
    Melbourne's East side
    FWIW, R tails are not on when DRL,s are activated, probably not much help, but just a follow up anyway. Hope you get it sorted
    Current ride..MY10 Golf MkVI GTI | 5 dr | CW | < DSG >| Leather| Dynaudio | Sensors | Tint | R tails
    Current ride...MY12.5 Polo 6R GTI | 5 dr | CW | Xenons | Alcantara Leatherette /4
  4. #674
    Oct 2009
    Quote Originally Posted by ICEDIST View Post
    Ok. Thank you for checking that. I wonder what is going on. Now I really need someone to check that has installed them after market with the Xenons & LED DRLs
    I can't understand why the MY11.5 would be any different as far as operation other than for the Xenons. Hope it is just a coding thing. I also noticed this though:
    About 5 seconds after I turn on the car the fog light flickers??????
    MY14 CLA45 AMG
  5. #675
    Found this post further back in this thread Backdoc.....knew I had read it somewhere
    Quote Originally Posted by solistics View Post
    Something I noticed the other day (whilst admiring my tails in the reflection from a glass door I was parked in front of...sad I know.) is that the fog light flashes 3-4 times when you start the car and the MFD is cycling through the errors.
    PS Mine also did this, once recoded it stopped
  6. #676
    Thanks
    I have an 11.5 with Xenon and LED DRL, fitted with the R-Tails. They work as advertised! Which Hex Code did you use to code the car? I found "04" was the only one that worked. I have CE version 0615 BTW...
    Now - MY17 Passat 206TSI Wagon - Tungsten Silver | Sunroof
    Previous - MY11.5 GTI 5Dr - Reflex Silver | DSG | ACC | Sat Nav | RVC | Bluetooth | MDI | 18" Detroits | Park Assist | Bi-Xenon's | Leather | Sunroof | R-Tails
  7. #677
    Oct 2009
    Quote Originally Posted by GTI mk6 View Post
    Originally Posted by Escell
    the MFD does cycle through the four light warnings every time you start the engine. But I barely notice anymore and it's been 24 hours.
    Champion. So that explains that. Be interesting to see if recoding removes that flashing? Reminds me of when I attached my Kart trailer with LED lights - car freaks out with that too.
    So, still need to work out the relationship with the LED DRLs.
    Thanks again.
    MY14 CLA45 AMG
  8. #678
    Sorry mate, I just re edited my post, originally copied and pasted it incorrectly oops
    As soon as mine had been recoded, I stood at the back of the car and watched the guy turn the ignition on and off a couple of times
    to make sure the fog didn't flash anymore.....all good, no problem.
  9. #679
    Oct 2009
    Quote Originally Posted by chopper View Post
    Chopper, your my man (so to speak). Can you please confirm when your headlights are OFF, LED DRLs are ON, that your R-Tails are OFF? If this is the case, is there any chance you recall prior to recoding if they worked together? My R-Tails only go OFF when my LED DRLs are switched OFF too.
    MY14 CLA45 AMG
  10. #680
    Hey Mate,
    Yep... when the car is running during the day and my lights are set to Auto, LED DRLs are on, headlights and R-Tails are off. My lights work EXACTLY as they should!
    Sounds to me like a coding issue... it took 3 different codes before "04" worked for my car. How many codes did you try? Are you using "04"?
