Yeah good price but wrong set, you can get them from TMTuning in the states for the RHD cars, all up a little under $1000 plus shipping which is around US$40 from memory
VW OEM Golf Mk6 taillights
Yes, you need to make sure they are the right configuration as Corey said. There are a few different options, apart from reverse & fog being reversed, the US has 2 reverse lights and no fog.
You will also need adapter cables as they are a different electrical connection to the Golf.
Lastly, you will probably need to access a Vagcom to code them.
GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
Only for LHD I think Nath.
I'm in contact with TMTuning about their code box (a device you plug into your ECU port to set the necessary bits, that allows you to get away without VAG-COM). Their response suggested it'd work a treat for us here in Aus, but I've sent a reply requesting explicit confirmation whether the code box will work for Australian delivered cars or not.
Ozram, have you ordered from TMTuning?
Somone is selling a pair of these on vwgolf.net.au...
I have a set of LHD tails for my car and they throw a fault code for the foglight.
This fault code means you lose steering wheel controls for the stereo.
I will have to see how easily they can be modified to be compatable but as far as i can tell it is going to require a fair amount of work.
I know the luight surrounds are fine, it's just the light assembly as there is no provision for the left foglamp and the light assembly for the RHD cars doesn't clip in at the same points.
Sorry for the slackness of my follow-up. Got this from TMTuning in response to my query ref the code box:
...so presumably RHD Australian models are covered.Originally Posted by TMTuning
I am pretty tempted to go ahead and get these (Ozram - I agree they are very expensive, but am not sure of the alternatives; how did you locate your German dealer?). But I'm still not 100% convinced by the code box. Has anyone else had any experience using these to make changes to their car in the absence of a VAG-COM? I hope they're smart enough to perform checksums and so forth to ensure they're setting the right bits, and don't make changes that could cause problems.
