Page 10 of 118 FirstFirst ... 891011122060110 ... LastLast
Results 91 to 100 of 1178
Thread: Mk6 LED Taillights
  1. #91
    Apr 2009
    Quote Originally Posted by vainbt View Post
    anyone has done this yet??
    500 euros shipped from Germany... approx 700 AUD......
    very tempting..
    Yes, I have. But not from Kufatec. They should be leaving Germany tomorrow or Tuesday
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
  2. #92
    Nov 2009
    Yeah good price but wrong set, you can get them from TMTuning in the states for the RHD cars, all up a little under $1000 plus shipping which is around US$40 from memory
    VW OEM Golf Mk6 taillights
  3. #93
    Apr 2009
    Quote Originally Posted by sharkablue View Post
    Im coming into this thread abit late, But are their any right hand drive lights avaliable to order?
    I found these however im not sure if they are signed for RHD Markets?
    Yes, you need to make sure they are the right configuration as Corey said. There are a few different options, apart from reverse & fog being reversed, the US has 2 reverse lights and no fog.
    You will also need adapter cables as they are a different electrical connection to the Golf.
    Lastly, you will probably need to access a Vagcom to code them.
  4. #94
    Nov 2009
    Quote Originally Posted by Ozram View Post
    You will also need adapter cables as the are a different electrical connection to the Golf.
    Agreed however I think you can get a code box if you dont have access to a VAGCOM connection
  5. #95
    Apr 2009
    Only for LHD I think Nath.
  6. #96
    Nov 2009
    I'm in contact with TMTuning about their code box (a device you plug into your ECU port to set the necessary bits, that allows you to get away without VAG-COM). Their response suggested it'd work a treat for us here in Aus, but I've sent a reply requesting explicit confirmation whether the code box will work for Australian delivered cars or not.
    Ozram, have you ordered from TMTuning?
  7. #97
    Feb 2009
    Somone is selling a pair of these on vwgolf.net.au...
  8. #98
    Jun 2009
    Quote Originally Posted by hoi polloi View Post
    I agree...
    Note also that these appear to be for LHD cars only (note the rear fog light on the driver's side). Can you get them for RHD cars or are the LHD ones easy to convert?
    Regards,
    - Anthony
    I have a set of LHD tails for my car and they throw a fault code for the foglight.
    This fault code means you lose steering wheel controls for the stereo.
    I will have to see how easily they can be modified to be compatable but as far as i can tell it is going to require a fair amount of work.
    I know the luight surrounds are fine, it's just the light assembly as there is no provision for the left foglamp and the light assembly for the RHD cars doesn't clip in at the same points.
  9. #99
    Apr 2009
    Quote Originally Posted by AdamD View Post
    No mate, A german VW dealership. I think $1000 is too much from TMTuning. I also think the ones for sale on here and on vwgolf.net are too expensive. But that's my opinion. Mine cost considerably less than either of them.
  10. #100
    Nov 2009
    Sorry for the slackness of my follow-up. Got this from TMTuning in response to my query ref the code box:
    Quote Originally Posted by TMTuning
    It will work regardless of your country yes.
    ...so presumably RHD Australian models are covered.
    I am pretty tempted to go ahead and get these (Ozram - I agree they are very expensive, but am not sure of the alternatives; how did you locate your German dealer?). But I'm still not 100% convinced by the code box. Has anyone else had any experience using these to make changes to their car in the absence of a VAG-COM? I hope they're smart enough to perform checksums and so forth to ensure they're setting the right bits, and don't make changes that could cause problems.
